Question about Brother MFC-8460N All-In-One Printer
Hp MFC-8640n I believe I need a new fuser for residual printing
Is the fuser something I can change easily????
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Are you handy? Not very hard. I can give you the part number and a price on the part. email me jtuminaro@officetechservice.com
Posted on Jan 16, 2009
Hp color laser jet 1600
If you can rub off the colors easily with your finger then it is the fuser wire. Maybe the high voltage isn't enough to pull the toner to the drum. It's not something you can fix. Needs to go into a repair shop.
Jan 28, 2014 | Office Equipment & Supplies
Left edge black on hp laserjet printer
Fuser teflon sleeve got damaged, replace it.. (only professionals can do this activity) if its not available go for new fuser assembly..
Jul 31, 2012 | HP "LaserJet P2035n Printer"
The IT Dept. at work gave me a Laserjet 2420. When I print something, it appears that ink is stuck to the roller and will reproduce faded lines further down in the page. I would describe it as the toner is...
Faulty cartride or fuser causes ghoost image in print outs. Primary level:check with another cartridge. Secondry level: Remove fuser assm out, check teflon sleeve surface deposited with toner?. replace teflon sleeve if available if not replace fuser assm. In fuser modes we can increase/decrese the temparature of fuser.
Note: only service engineer can replace the teflon sleeve.. user not advisable
Sep 21, 2011 | HP LaserJet 2420 Printer
Verticle lines printing on laser printer
Check the fuser. If it is the fuser, you should be seeing 3 dark lines on the fuser film. Here is the picture about how the film looks like:
Changing the film usually solve the problem. However changing the film itself is difficult. You have to remove and basically disasseble the fuser, and change the film. However it is fairly cheap and if you decide you would like to save some money, here is the link available in ebay:
http://cgi.ebay.com/Fuser-Film-Sleeve-HP-LaserJet-P3005-RM1-3740-/250558576965?cmd=ViewItem&pt=BI_Toner&hash=item3a56747945
Or, simply search for 'P3005 Fuser Film' and you will find a lot.
Other than that, you can change the entire fuser. Please note that fuser for P3005 is not consumer installable part. You still have to take out some parts in order to change the fuser.
The parts are available from many parts supplier. Simply google 'P3005 fuser'. Usually around $100 for a refurbished fuser.
You can also recycle your old fuser and get some moeny! (about $15-$25 per fuser).
Apr 09, 2010 | HP LaserJet P3005n Printer
My MFC-7820n was printing perfectly and now, suddenly, all pages are very light and most toner doesn't seem to be fusing to the paper. The page 'sort of' prints but it's illegible. I have installed a new...
If the toner is not getting completely fused to the paper (i.e. you can rub it off with your fingers either completely or partially), then there is something wrong in the fuser section. The fuser is nothing more than two rolls pressed together with heat lamps inside (usually just one roll has a lamp). Perhaps a spring fell off? or the lamp is burned out.
Dec 06, 2009 | Brother MFC-7820N Printer
HP LASERJET 3330 printing quality is poor (on & off problem). It's double printing,scattered ink, and barely printing other times. I tried a new ink cartridge, replace the pick-up roller, and did some...
Based on the steps you've already taken, it sounds like you need to replace the fuser unit. The fuser is what melts the toner to the paper and over time it wears out. Some service techs call it "ghosting", when it seems like it reprints a image. Check your local repair companies and tell them you need to replace the fuser, the part number is RG9-1493-000CN. This part isn't something that can be easily changed out, it involves removing the top scanner and other components. Let me know if there is anything else you need.
Jul 29, 2009 | HP LaserJet 3330 All-In-One Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
New problem with hp 3380
hiii...
change the fixing unit....film inside fuser.....
Sep 15, 2008 | HP LaserJet 3380 All-In-One Printer
HP Laserjet 1200 not printing in one area
your fuser is truly unhappy..time for a new fuser
May 28, 2008 | HP LaserJet 1200 Printer
Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
Apr 07, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC-8460N All-In-One Printer Logo
505 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
