Question about NAD T762 Receiver
Gp280bvk x3 i am loking for a rechargable batterie # gp280bvk x3 for a wireless headphone Recotton model #1682 k965
I have the same headphones. I went to Batteries Plus and purchased a similar battery, NUON, NU67, 3.6v 320mAh. The original battery is 3.6v 280mAh. The 320mAh holds the charge longer. You must swap the connector from the old battery to the new battery in order tomake it work. This can be done two ways, carefully removing the connector or cut, splice, solder and insulate the battery leads. Removing the connectors is tricky because the leads lock into place when inserted into the connectors. Good Luck.
Posted on Feb 07, 2009
How do I connect a wireless head set to a Dynex Television Model DX-37L200A12
Using the appropriate cable for the transmitter that came with the wireless headphones, connect one end of the cable to the AUDIO OUT jack on your TV set and the other end to the AUDIO IN jack of the transmitter. If your headphones came with rechargeable batteries, don't forget to charge them before using the headphones.
H
Dec 08, 2014 | Dynex Computers & Internet
I changed my batterys and now it wont let me talk or hear threw the mic
What type of batteries did you use? It's best to use new, fresh from the package alkaline AAA's. You can use NiMH rechargeable batteries, but make sure that they're fully charged up. Some say they come fully charged, but they might not be.
Jan 06, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
Popping sound in the Rocoton Advent Wireless speaker
Double check your connections at the transmitter. Swap inputs to see if the popping moves to the other speaker. Popping usually means blown, however......
Dec 13, 2009 | Recoton Advent Advent AW810 Main / Stereo...
My turtle beach is buzzing!!! PLEASE HELP!!!!
The X3 uses infra-red (IR) wireless, which is at the same frequency as interference from many plasma TV sets. Do you have a plasma screen TV?
Jul 29, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
Turtle Beach X3 is usually not recognized when plugged in
Change the batteries. The light will stay on when the batteries are too low. When that happens, you'll get symptoms like this.
Jul 15, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
I can't hear any of the gameplay audio through my brand new X3s..
You have to connect the red/white RCA audio cables that came with the X3 in-between the audio cables that are going to your TV.
Jun 06, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Sennheiser TR136 Wireless Headphones Nothing Happens
Replace the NiMh batteries. They might be bad. Could happen during power surges as you indicated you had. Let them charge up fully 14-18 hours as the book suggests.
Aug 25, 2007 | Sennheiser RS115 Wireless Headphones
NAD T762 Receiver Logo
701 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
