Question about HP LaserJet 1100a Printer
Scanning i am begineer and want to learn that how scanner works
  • 72 Answers
You need to download scanner software for that unit then put what you want scanned in the scanner slot & the pc should see it.
Posted on Jan 16, 2009
Radio Shack 16a Handheld Scanner
I had the same problem and when this happens I just press and hold the scan button until it beeps and begins to scan again.
Dec 10, 2013 | Radio Shack Pro-97 Handheld Scanner
I cannot get mu VuPoint to scan. I have batteries in. I hit the scan button and then nothing. Is there a step that I need to do before I begin using the scanner? Does a little light come up when...
I had the same problem until I set the time and date. Not sure if this was the problem but it worked after setting these things. I went through the "Using the Scanner" section in the documentation.
nic
Dec 22, 2010 | VuPoint PDSST410VP
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Motorola MC3090 do not read barcode starting with zero
look online there are learning barcodes out there you can scan, look for one with zero in front, if you are making the barcodes yourself than put a * at the beginning and end and then make barcode, it will capture everything in between,
Aug 26, 2009 | Symbol Motorola MC3090 Handheld Computer
Acer 1240UT scanner not working with vista
The new drivers off of HP are a basic version which give you none of the nice features of the 7400c.
The seem to have discontinued the scanner and now just give you a basic set up which sucks.
It will work under the Windows Fax and Scan but don't be looking to scan an individual picture, crop it and save it as anything other than a jpg or bitmap... lessons to be learned, don't lose your original discs!!! does anyone out there have the original software?? please help
Jan 04, 2009 | BenQ 5000U Scan to Web Scanner
Epson CX4200 scanner
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan.
Jul 10, 2008 | Epson Stylus CX4200 All-In-One InkJet...
It begins but ....
Try another USB port. I had the same problem when I tried using the front USB ports on my computer. It works fine after I plugged it into one of the back ports.
If that still doesn't work, you may need to buy a USB card.
Jan 05, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Scanner incorrectly reads frame position on film
Yes there is
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Scanner
There is glass platen and on its sides you can see the markings to place various paper sizes. Just follow them as per your paper size.
Oct 05, 2007 | Epson Perfection 1240U Flatbed Scanner
HP LaserJet 1100a Printer Logo
57 people viewed this question
Ben Johnson
