Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Sony kdf-60xs955, rear projection tv
Tv will not turn on with 6 red flash code
  • 4 more comments
  • cracrew Nov 13, 2007
    I have the same problem do you have any info on the thermo fuse part number removal instruction. thanks
  • totoyz Mar 11, 2008
    I have the same blinking 6 times on my KDF-60XS955. Any help you could give me regarding fixing this problem would be greatly appreciated. Thanks to all.
  • Anonymous Apr 02, 2008
    did all trouble shooting instructed in service manual still get no picture only 6 red light blinks at a time
  • djdb1 Oct 01, 2008
    Hi, I have a sony projection tv and, having similar problems it will start to flash a big red screen similar to a flash bulb but red then seconds later turn it self off. then flash a 5 blinking code. Need Help! Thanks
  • Anonymous Apr 03, 2009
    how to install themal fuse on a50 inch sony wega
  • Anonymous Mar 20, 2014
    Red lite flashing on control panel
    Scholar:
  • 150 Answers
There is a Thermal fuse under the lamp housing that opens up and Sony has a New style fuse to replace it with, it opens up one of the p/s lines to set code 6, replace with new thermal fuse and test. You will want a Skilled Professional to replace this fuse as it does require some dissassembly and removal of light engine to remove fuse from under lamp housing to put new one on side of lamp housing.
Posted on Jul 04, 2007
SOURCE:
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony model # KDF-60xs955 with blinking red code
you have to check all voltages if bad or good! check the hot side section if have a voltage! maybe you have defective oscillation circuit in hotside.
Oct 08, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Red light flashing no picture or sound
Please check Lamp in TV that seems broken and causing red light bliknking on TV front, if it is Sony KDF-60XS955
If model is different, please mention it so to provide you proper helpful info.
Let me know if you need further info.
Thanks.
Nov 23, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
KDF-60WF655
5 red flashes on your Sony indicates the power supply for lamp is not working .Or 5 pin harness to it is not seated properly.Possibly needs replacement..
Aug 01, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
What the @*#@*#
The 4 blink fault code means one of the fans is faulty or the H4 module in the TV.
Jun 07, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
1,284 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
