Question about SPSS 13.0 (30960UU)
Client and server data are out of sequence
When i input data in data view i read the above statemet. why is that so and what can be done to alter?
Change permissions
You should be able to alter its settings by right click on the icon, select properties then alter permissions.
Feb 04, 2014 | Toshiba HDTC605XK3A1 Canvio 3.0 Portable...
My phone memory had been corrupted. How can I recover it?
in simple terms: there is no way to recover the corrupted data.
in detail: the data on the phone is stored as a series of 1's and 0's in patterns in the memory. if the series and/or patterns are altered in any unconventional way it will become "corrupted", like in this case,and the phone would not be able to "understand" what it is reading. also, the phone would not be able to "remember" the original series/patterns because they were altered by unconventional means. a backup would correct this problem but backups for phones tend to contain essential system data(for running the phone itself) and only have enough space to store said data.
Oct 17, 2013 | Nokia E63 Cell Phone
Website not displayed error http 500
The Web server (running the Web Site) encountered an unexpected condition that prevented it from fulfilling the request by the client (e.g. your Web browser or our CheckUpDown robot) for access to the requested URL.
This is a 'catch-all' error generated by the Web server. Basically something has gone wrong, but the server can not be more specific about the error condition in its response to the client. In addition to the 500 error notified back to the client, the Web server should generate some kind of internal error log which gives more details of what went wrong. It is up to the operators of the Web server site to locate and analyse these logs.
500 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with the Web server:
  • Obtain an IP address from the IP name of the site (the site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from the Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '500'. (Last updated: March 2012).
Fixing 500 errors - general
This error can only be resolved by fixes to the Web server software. It is not a client-side problem. It is up to the operators of the Web server site to locate and analyse the logs which should give further information about the error.
Fixing 500 errors - CheckUpDown
Please contact us (email preferred) whenever you encounter 500 errors on your CheckUpDown account. We then have to liaise with your ISP and the vendor of the Web server software so they can trace the exact reason for the error. Correcting the error may require recoding program logic for the Web server software, which could take some time.
Jan 28, 2013 | Facebook Social Network
How do I prevent the date and time from being available on the camera data?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. If you don't want this data attached to the photo, you'll have to use a photo editor capable of altering this metadata. With most programs you won't be able to remove the data completely, but you should be able to set it something like midnight on January 1, 2000.
Dec 10, 2012 | Cameras
Keek -forbidden(error 408) solution
HTTP Error 408 Request timeout
Introduction
The Web server (running the Web site) thinks that there has been too long an interval of time between 1) the establishment of an IP connection (socket) between the client (e.g. your Web browser or our CheckUpDown robot) and the server and 2) the receipt of any data on that socket, so the server has dropped the connection. The socket connection has actually been lost - the Web server has 'timed out' on that particular socket connection. The request from the client must be repeated - in a timely manner.
408 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '408'. (Last updated: March 2012).
Fixing 408 errors - general
408 errors are often difficult to resolve. They typically involve one-off variations in system workload or operations.
If you see persistent 408 errors, the first thing to consider is the workload on the Web server - particularly around the time the 408 errors were generated. If this is light, then you also need to consider workload on the client system. If the computer systems on both ends of the socket connection seem to be running normally, then temporary Internet surges may be to blame.
Fixing 408 errors - CheckUpDown
This error is highly unlikely to occur on your CheckUpDown account, because there is usually only a tiny interval of time (milliseconds) between our 1) opening of the socket and 2) writing the HTTP data stream through that socket. In exceptional circumstances, this interval may increase because of some operations on our computer systems e.g. we temporarily suspend an executing process and this happens immediately after the socket was created. Or the two steps may follow quickly on our systems, but the second step encounters an unreasonable delay on the Internet. The acceptable interval between the two steps could also be set very low on the Web server e.g. the Web server is very busy, and has become a bit 'impatient' with attempted connections it views as a bit slow.
Any of these conditions may generate an 408 error. But they are all fairly unlikely to occur. In normal IP communications, the time interval between the two steps should be much less than 10 seconds, which should be completely acceptable to the Web server.
I hope this helps.
Oct 23, 2012 | Computers & Internet
HOW CAN I CONFIGURE MY HANDY CAFE SERVER AFTER I INSTALL
cant view my client in handycafe my net and router r ok last night i can view but now there gone
Mar 01, 2012 | Ates Software HandyCafe
What does 192,168,1,254 mean?
Your server may be In Active mode, the FTP client chooses the port number that it will use to transfer data on and tells the server which client-side port to send the data to. It issues the PORT command to let the server know what IP address and Port number it will be listening on to receive the data from the server.
PORT 192,168,1,254,4,15 The server then initiates the data transfer to the client, sending the data to the port number that it was told to by the client. Since the Server has initiated the connection, a stateful firewall will not allow the data to be sent back though. (No client has created the connection and so no respective connection exists.)
Hope this helps.
Good Luck
C2Solutions
Feb 16, 2012 | Dell Computers & Internet
I want to change my language
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
See page 28 of the user's manual in the ADJUST TEXT INPUT section for detailed instructions on how to alter the primary and secondary language preferences on your device.
Basically you just tap the SETUP button on the application launcher screen. Then tap INPUT SETUP to open the input settings screen. Then just adjust the settings to your preferences and SAVE.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.motorola.com/staticfiles/Support/HK-EN/Mobile%20Phones/MOTO-A810/HK-EN/_Documents/Static-files/A810_ENG_HK_UG.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 18, 2011 | AK Mobile BRAND MOTOROLA A810 BLACK 1YR...
Alter time onAQ-180W
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3793.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
Joe.
Nov 25, 2011 | Casio Watches
What is the meaning of HTTP 411
http://www.checkupdown.com/status/E411.html
HTTP Error 411 Length required
Introduction
The Web server (running the Web site) thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) should include a 'Content-Length' specification. This is typically used only for HTTP methods that result in the placement of data on the Web server, not the retrieval of data from it.
411 errors in the HTTP cycle
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '411'. Frank Vipond. September 2010.
Fixing 411 errors - general
This error seldom occurs in most Web traffic, particularly when the client system is a Web browser. The problem can only be resolved by examining what your client system is trying to do then discussing with your ISP why the Web server expects a 'Content-Length' specification.
Fixing 411 errors - CheckUpDown
This error should simply never occur on your CheckUpDown account. If it does, it typically indicates defective programming of our systems or of the Web server which manages the site. The 'Content-Length' specification is irrelevant to the type of access we use when we check your URL.
Please contact us (email preferred) whenever you encounter 411 errors - there is nothing you can do to sort them out. We then have to liaise with your ISP and the vendor of the Web server software to agree the exact reason for the error.
May 24, 2011 | General Computers & Internet
Computers & Internet Logo
1,462 people viewed this question
Top SPSS Computers & Internet Experts
David Payne
David Payne
Are you a SPSS Computer and Internet Expert? Answer questions, earn points and help others
