Question about Maytag Performa PAV2200
Water leaks from the sides when I turn the washer on
When i turn the washer on the water leaks from the sides as fast as it goes in. The water seems to come from the bottom between the seams of the metal
  • 61 Answers
OMG i got bad news for you the top seal and bearing is bad you need to compleatley diasemble this machine to replace this normaly while im in it this deep i go ahead and replace the gear case if i had to pay for the parts and labor to do this i would buy a new washer.
Posted on Jan 16, 2009
I have LG wm-2277HW Front Load Washer, when I pour bleach into the bleach dispenser I see it disappearing as fast as I pour it in,and I see it coming out the front bottom the washer (the same side) where...
Remove the screws on the back of the top and lift the top off. Pour water into the bleach dispenser and watch to see where the leak is coming from. Post back your findings.
Dec 07, 2012 | LG WM-2277HW Front Load Washer
Have maytag side by side where the water goes in the back it is leaking bad
The water inlet control valve in the washer is broken and needs to be replaced.
Turn the water off at the wall as it will continue to leak until you can get it repaired.
Jun 26, 2012 | Maytag Refrigerators
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Samsung washer is leaking water from under the front of the machine. not from the door. the drain pump works.
after it leaks, place machine on its side, look for wet spot, may be popped off hose or leak at pump, or rarely cracked drum if plastic.
Sep 02, 2009 | Samsung WF328AA Front Load Washer
Leaking from the seams of the washer when I turn it on
sound like you have a hole in the hose between the pump and tub if not you eather have a hole in the tub or the seal and bearing where the gear case goes through is worn out realy by ir this is the case you would have had some water leaking for a while though.
Jan 16, 2009 | Maytag Performa PAV2200
Water leaking when washer is filling
  • Is the water coming from the front center?
  • if it is it is coming from the water pump.
  • just let me know which side and how fast it is flowing
Jul 02, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool MDLslr8233eq0
my lg and others with the 1814 model, seem to have the problem also, watch the back side whenit goes into the rinse cycle , on mine @aout 7-8 minutes left. mine was blowing out suds and water through what is an air vent , i think. if lots of models hav this problem, we might be able to get lg to do something.
Mar 10, 2008 | LG WM1814CW Front Load Washer
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
