Question about Maytag Performa PAV2200
Leaking from the seams of the washer when I turn it on
When i turn on my washer the water runs out from the sides as fast as it goes in.
  • 61 Answers
Sound like you have a hole in the hose between the pump and tub if not you eather have a hole in the tub or the seal and bearing where the gear case goes through is worn out realy by ir this is the case you would have had some water leaking for a while though.
Posted on Jan 16, 2009
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
Ford mondeo 2002 Zetec 2.0 motor ..Have a small or slow water leak comming from front of motor behind water pump area ,above air con unit, where water hose goes into the motor ..very hard to see where it's...
Starting from the top down dab every joint and seam with kitchen paper towel. Between each dab and press examine the kitchen towel for dampness. It is vital that you find out exactly where the leak is coming from. You could be lucky and the leak might be fixed buy an extra half turn on a jubilee connector on a hose union or a quarter turn on the water pump or thermostat housing bolts. If the leak persists you may require a new gasket . If the leak is from the water pump shaft seal behind pulley you will see a tell tale stain on the 'chin' of the pump body. This will require a replacement of the pump.
Sep 02, 2010 | Ford Focus Cars & Trucks
Water leaks from the sides when I turn the washer on
OMG i got bad news for you the top seal and bearing is bad you need to compleatley diasemble this machine to replace this normaly while im in it this deep i go ahead and replace the gear case if i had to pay for the parts and labor to do this i would buy a new washer.
Jan 16, 2009 | Maytag Performa PAV2200
My front load washer is leaking water during the spin cycle
It sound like the hose that goes to your water pump under the tub might be loose or the pump is leaking. I hope this helps you out
Nov 30, 2008 | Kenmore 43142 Front Load Washer
Leaks occur in spin/empty cycle
I had the same problem, you need to turn the washing machine on it's side and look for a pin hole leak in the seam of the plastic holding drum on the bottom. I used a silicone sealant, "GOOP" , let it dry for 1 day and problem solved. It has not leaked in two years. good luck!
Nov 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Water leaking when washer is filling
  • Is the water coming from the front center?
  • if it is it is coming from the water pump.
  • just let me know which side and how fast it is flowing
Jul 02, 2008 | Kenmore 24032\24036 Top Load Washer
Washer has water running in it
It sounds like you have a defective water inlet valve. This is where your fill hoses connect to the back of the washer. The valve usually has two electrically operated solenoid valves (one for hot, one for cold). These solenoids can go bad and cause the valve to leak by. The valves can also become clogged with sediment and not close properly, also causing leak by. If you have hard water this could be the case. Also, low water pressure can sometimes cause these valves not to seat properly. A minimum of 10-25 psi is required at the taps. If you've never had a water pressure issue in the past, I would doubt this to be your problem. You can try cleaning the valve to see if this helps. But, if you're going to go through the trouble of removing the valve to clean it, you might as well replace it so you don't have to repeat the process later.
To access, the valve you will need to remove the top panel of the washer by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the top will slide back, then off. The fill valve will be located on the left hand side in the rear of the washer.
If you desire to replace it, a new valve can be found at searspartsdirect.com. Just type in your complete model number in the Search window and look under the "Dispenser Parts" heading for item number 1 (part #8181694).
If you need instructions on how to replace the valve, please let me know. I hope this helps you.
May 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
