Question about Sony SDM-HS95 19" LCD Monitor
Power of the Monitor keeps going out.
My Monitor just went out and when i pressed the power button it keeps just shutting off again, the green light is still on but the picture wont stay on..
  • biggmacklyon Jan 17, 2009
    Well i tried that and still nothing, i grabbed my mom monitor and it works fine. would it be that it blew?
  • Anonymous Apr 03, 2009
    Monitor going black after 2 seconds
    Problem Solver:
  • 23 Answers
You need to look inside your pc and check and see if the video card is plugged in tight. Sometimes if it is loose, and it isnt connected, and causes the monitor to not show any picture, but still has power.
Posted on Jan 16, 2009
  • tiffaniross
    tiffaniross Jan 17, 2009
    It could be a faulty monitor, possibly something lose on the inside. Is it a new one? or an old one?
    If it is under a year old, most manufactures carry a warranty on them.
How do I fix Canon error message 2700?
Dear
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Thanks.
Feb 15, 2015 | Canon PIXMA Office Equipment & Supplies
Red and green lights work fine, but after green off completely, help?
Generally If System Is Unused For A Certain Amount Of Time Time It Will Go Into Was Is Called Sleep Mode. Also Make Sure You Locate Your Fan And Make Sure Its Able To Pull In Air For Ventilation Which Keeps The System Cooled Down And Wont Allow System To Get Hot
Mar 17, 2012 | Sony Playstation 3 (PS3) Console
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
I have viewsonic 1703wb monitor. Often Monitor power went off
Check the power cable. If it uses a power brick style assembly (like a laptop) it may need to be replaced. Some power bricks can break a wire at the base of the brick just enough that it causes a short in the system and shuts down the power flow.
Mar 19, 2009 | ViewSonic VA1703wb Monitor
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
Monitor problem
erickalin - it sounds like your computer might have shut down and failed to come back up again. If you have access to another monitor, try hooking it up to your computer instead of the one you normally use (that won't stay on). If the second monitor won't stay on, the problem is your computer. You might have to take it to your local computer geek or computer store to get serviced. If your computer DOES work with the second monitor, you might need to have your monitor serviced or replaced. Good luck!
supposed2b, I think you have the same problem, although your computer doesn't even sound like it's powering up. Your power supply might be faulty or an internal component (CPU or memory most likely) of your computer has died. Double check your power connections and ensure that when you press the power button you hear the computer start up and the light on the front comes on (hopefully green or blue, but not yellow or red). Again, you might need to take your computer in for service.
Jun 10, 2008 | Computers & Internet
Sony SDM-HS95 19" LCD Monitor Logo
190 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
