Question about Hotpoint Washing Machines
The water pours out of the bottom of the washing machine
When the water starts into the machine, it pours out of the bottom of the machine immediately. I think maybe it it a gasket or hose, but I would like to be able to repair it myself.
    Scholar:
  • 30 Answers
I think that you have a bad water jet. They are located inside the cabinet at the bottom of the washing machine. Mine was on the left rear corner, inside the cabinet to the side of the tub. Follow where the water hose goes into the washer. You will be able to fix it yourself. I didn't lay the washer down, the cabinet panels come off. Good luck. I have faith that this will be a breeze for you.
Posted on Jan 16, 2009
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Sep 13, 2017 | Bosch Logixx WFT 2806 Front Load...
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
We have a Miele W830 Novotronic washing machine. Water started pouring out the bottom l.h. door from drain pump area when we tried to do a load of washing tonight. We've taken it out and cleaned it...
Although this answer is obviously not current any more I thought it may help others. We recently had the same problem with our machine. The clamp holding the hose to the detergent drawer became loose and the hose came off, allowing water to pour right down to the drain pump area. By undoing the 3 screws behind the detergent drawer + the 3 bolts around the door, I was able to open the front of the machine and tighten the hose clamp.
ozfix
Oct 18, 2009 | Washing Machines
Washer won't start. water pours down sewer pipe
Hi, If the water is going out the drain hose, raise the drain hose so that its highest point is as high as the top of the washer. This should take care of the issue. If the water is coming out of the bottom of the machine, tip it back against the wall and look under the washer to see if a hose has broke or came loose.
If I can assist you further, please let me know.
Vic
Jul 18, 2009 | Roper RAS8445KQ Top Load Washer
WHEN I TURN WASHER ON WATER STARTS POURING OUT OF THE BOTTOM OF THE MACHINE AND ONTO THE FLOOR. WATER IS COMING FROM THE BOTTOM LEFT SIDE.
The drum seal is bad. The seal allows the center to come up through the tub and the tub to rotate around it, It usually has a rubber membrane that flexes so the tub can rock around. The rubber tears and the water runs right out. If you can, disassemble the washer and change the seal, otherwise the washer is toast. Sorry! You can verify this by pouring water in from a bucket. If this water doesn't run through then it is the hose from the fill valve to the water outlet under the lid.
Jun 08, 2009 | Washing Machines
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Doesnt stop pouring water
it is suppose to turn off, bad fill valve.
Nov 08, 2008 | Washing Machines
Washer Maytag
the drain hose tear or broken/ clamp detached / need to replace.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
