Question about Samsung HLP4663W 46" Rear Projection HDTV
Replaced colorwheel and now we have blue images
Had whinning/bussing noise - replaced color wheel (easy) - no noise, but now we have blue images.
I heard there is a jumper cable fix or possibly a CCA setting fix. Is it one or both and how do I fix problem.
THX - Bill
  • bill1655 Jan 16, 2009
    Removing jumper will will correct display colors. Does anything have to be done with CCA settings?
  • dbutler331 Feb 27, 2009
    I have a picture on my 3 and 1 half year old projection samsung but the colors are tinted and there are blue highlights in a curve sagged across the screen.
    Champion:
  • 240 Answers
Remove the small black pin jumper in the back center of dvm modual.
it looks like a larger hard drive jumper.
ther is a squair hole cut in the tin bach mesh
use tweesers to remove the black jumper.
Posted on Jan 16, 2009
My RCA Scenium blew it's lamp. When i replaced the lamp there is still no picture (black screen)and panel lights will blink 5 times. Could this be my color wheel?
It could be the colorwheel but if you dont hear any whinning before the light starts blinking 5 times its probaly the AC in board especially if you have the ATC336 chassis RCA
Apr 03, 2012 | RCA Televison & Video
I have a 52" DLP samsung tv I believe the motor
It sounds like the color wheel needs replacement. Yes it can easially be done yourself. You can get the colorwheel with instructions from www.tvrepairworld.com
Sep 15, 2011 | Samsung Televison & Video
Is it easy to change a color wheel like the lamp? or i need to take it to a tv specialist?
the colorwheel is not as easy as the lamp to change. you have to remove the light engine from the tv and remove a cover from the lens and a cover from over the colorwheel then two screws that hold the color wheel and two wires. sometimes new codes must be input into the service mode. i suggest letting a professional do it.
Jan 30, 2010 | Samsung HL-R4264W 42" DLP HDTV
Color wheel
wrong color wheel..there are 2 colorwheels.you will need to remove a jumper wire...jumper is inside an opening abut 3/4 inch under label.
Apr 20, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Color is wrong after color wheel replacement
You probably replaced a bearing colorwheel, and it was replaced with a bearingless. If you look inside the TV on the back of the light engine (the silver box in front of and to the left of the color wheel), there should be a jumper (that connects two wires coming out) toward the bottom of it in a recessed little hole. That jumper should be removed if the color wheel was replaced with the air bearing type. Just grasp it gently with a pair of needle nose pliers, and pull it out slowly.
This should restore a normal color operation, but there might be some other adjustments that need to be made if it doesn't clear it up completely.
I hope this helps you...
Jan 22, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp model hl- S5086W making continious humming noise, has nothing to do with volume. Can I replace fan or wheel myself?
Most likely color wheel since most are defective right out of the factory--- someone has a step by step procedure to replace with pictures-- try google- samsung colorwheel -- fun job easy to do!!!
Jan 04, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel was making a sqealing noise then locked up
The clorwheel is the problem. Once the bearings go bad in the colorwheel, it's toast. Replace the colorwheel and you'll be ok
Dec 18, 2008 | RCA HD61LPW165 61" Projection HDTV
Problem with INfocus LP425z Colorwheel ?????
That unit has a bearing color wheel, if it was not stored proper, it could be sticking. That would explain the power cycling. giving it a bump start if you will. Yes you can open and inspect to see if color wheel "free wheels"
Feb 21, 2007 | InFocus SOFTCASE, LP425Z Multimedia...
Samsung HLP4663W 46" Rear Projection HDTV Logo
101 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
