Question about Canon PowerShot A710 IS Digital Camera
Cant unlock memory card
Cannon power shot a540 memory card is not locked but camera says it is
  • Canon Master
  • 4,738 Answers
The little slide switch may be broken inside the card. Do you have another card to try in the camera? If another card does work in the camera, then it's time to buy a new card. They're inexpensive these days anyways at about $6 for 2GB:
https://www.amazon.com/s/ref=nb_ss_?url=search-alias%3Delectronics&field-keywords=sd+card+2gb
Posted on Jan 17, 2009
Locked card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 23, 2012 | Patriot Sd Card 2gb Memory For Canon Power...
Window Vista not recognizing my Canon Power Shot A540 to download
I recommend getting a USB card reader for your memory card.
You should make sure that the camera is on for the transfer. If that doesn't work, try another USB input.
Nov 17, 2012 | Canon PowerShot A540 Digital Camera
Memory Card does not work in our Cannon 6.0 MP Power Shot A540. Message says Memory Card Error - Card Locked.
Turn off your computer the remove the memory card. Look at the card, it should have a small tab on the side that could be slide up or down to lock and unlock it. Just adjust it opposite from its position now and it should be fine.
Hope this helps. Thank you for using FixYa.
Apr 25, 2011 | Cameras
My memory card is locked and i tried everything i have a canon a540 powershot and the memory card is a sandisk 8gb
Have you noticed the slider on the side of the card? This acts as a lock and might have been accidentally moved to the locked position, in which case you could just move it back to unlock again. Hope this helps.
Dec 27, 2010 | Canon PowerShot A540 Digital Camera
Canon powershot A540 I have tried to erase memory card but it says card locked. How do I unlock.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2010 | Canon PowerShot A540 Digital Camera
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
May 28, 2010 | Canon PowerShot A540 Digital Camera
Memory card locked
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Feb 07, 2010 | Canon PowerShot A540 Digital Camera
I had the same problem with a card in my power shot A540. on the side of the card there is a little white slide-bar. Push that bar the opposite direction of where it is and see if that works. Good luck!
Jan 08, 2008 | Cameras
Canon PowerShot A710 IS Digital Camera Logo
177 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
