Question about Apple iPhone 3G
Iphone redials previously called numbers without touching screen
My iphone will redial a previously dialed number without me touching the screen. What causes this problem and is there a fix?
  • restrec Mar 10, 2009
    Exactly the same problem and it is disturbing for me and the other party. Any headsup?
4 Suggested Answers
vash_62000
  • 56 Answers
SOURCE: hi my iphone touch screen has stopped working
maybe broken or u cn restore it frm itunes and then unlok it wid iliberty software if ure not using at&t sim and then ur screen shud work or either press home and power button simultaneously fr 10-15 secs and itll reboot and if this dosent work uve spoilt ur phone and take it 2 apple service center they will make it right
enjoy
Posted on May 27, 2008
SOURCE: Iphone Screen Freeze
try holding down at the same time both the round button at the bottom of the phone and the on-off switch at the top
this re-sets the phone and all should work again
Posted on Oct 07, 2008
SOURCE: iphone black screen & buttons "pressed" while on call
I tried a solution to a similar problem and it worked for this problem, which I was having too. All I did was remove the leather case that I used to protect the iPhone. Calling and the screen worked like normal after I took the phone out of the leather case. Try that.
Posted on Mar 18, 2009
  • 8 Answers
SOURCE: iphone touch screen problem
Try pushing the power button and the home button at once and wait for it to restart, that should fixed the problem...
Posted on Aug 03, 2009
LOOKING FOR A MANUAL FOR lucent 9510 WIRLESS TELPHONE
Hi, Click this link for more data : http://www.vineland.org/tech/phones.pdf Regards, vote please, Jay
Lucent Telephone User's Guide (All Models) For corrections to this document, contact Steve Dantinne at sdantinne@vineland.org or 856.794.6700 x 2350 VoiceMail Welcome to Audix! The first time you use Audix you must record your name and create a password! To Log In: 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 1. The system will ask for your extension number followed by the # sign. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 2. Enter First Time Password # sign. Record Name As you use Audix, your name will be heard by you and other Audix users. Press 1 Speak your name Press 1 when finished Press # to approve Create Password You will be required to enter a new password with a minimum of 5 digits followed by the # sign. The maximum length of a password is 15 digits. Reenter your password for confirmation followed by the # sign. To Create a Personal Greeting This is what callers will hear when they reach your mailbox. Press 3 anytime you wish to do anything concerning your greeting Press 1 to create your greeting Press 1 to indicate the greeting number you are going to record then speak your greeting Press 2 then 3 to replay the greeting Press # to approve Press 1 to activate for all calls **X or **9 to hang up. To Get Messages 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 2. Enter your extension or voicemail number then press #. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 3. Enter your Password then press # You are now Logged in. Press 2 (You will hear the day, date and time the message was left and the length of the message. If the message is from another extension you will also hear the person's name and extension number) This is the header To play the message press 0 To listen to header again Press 2 then Press 3 To listen to message again Press 2 then Press 0 To Delete message Press *D To skip to next message Press # To forward Press 1 then Press 2 (record your comment) Press # when done recording. Enter the extension numbers you are forwarding to followed by #. Press # when done addressing. Press # to send. Call Handling Features Volume Control The volume control button will adjust three items. 1. If you are not using the telephone, it will adjust how loud or how softly the telephone rings. Press the up arrow to make the telephone ring louder. Press the down arrow to make the telephone ring softer. 2. If you are using the handset or receiver, it will adjust the sound of the incoming voice. The up arrow will make the voice louder. The down arrow will soften the voice. 3. If you are using your speakerphone, the volume control will adjust the sound on the speakerphone. The up arrow will make the sound louder. The down arrow will make the sound softer. Each item is independent of the other, depending on the device being used. That it what the volume bar will adjust. Hold The hold feature puts a call on hold until you can return to it. To keep a call on hold while you answer another call or perform another task. Press HOLD. The green light next to held call will blink. To return to the held call Press the call appearance button of the held call. Redial The Redial (or last number dialed), feature automatically redials the last extension or outside number dialed. To redial the last number that you dialed. 1. Press REDIAL. The last number you dialed is automatically redialed. Note: The redialed number can be an outside number, an extension, or a trunk or feature access code. Transfer The Transfer feature allows you to transfer a call from your telephone to another extension or outside number, if allowed. To send the present call to another extension or outside number 1. While on a call, press TRNSFR. (Dial Tone). Present call is put on hold, and the green light next to the held call blinks. You are given a new call appearance. 2. Dial the number to which the call is to be transferred. 3. Remain on the line and announce the call; if the line is busy or if there is no answer, return to the held call by pressing it's call appearance button. 4. Press TRNSFR again. Call is sent to the dialed number. 5. Hang up. ...............
Jan 21, 2011 | Cell Phones
My LG envy touch keeps redialing the most
This is because you might have enabled the automatic redail.Please put this to OFF so that it wont happen.
This option will be M enu--->settings---->Call settings
thanx
Jul 25, 2010 | LG enV Touch VX11000 Cell Phone
When putting the phone in the clip sometimes it will redial the last number called. I don't see any buttons on the outside that would redial. I know the right button on the right top brings back the last...
The right button on the right top that brings back the last dialled number may be the culprit. Check to see if a long press on this button redials the last number. If so, then the clip is pressing it too long. Can you avoid using the clip or modify the clip so as not to press this button.
Nov 09, 2009 | Motorola Mobility i560 Cellular Phone
Touch screen of phone on my iphone isnt working
Looks like your iPhone may be damaged.
Have you dropped it?
What kind is it the IPhone-iPhone 3G?
If you can give us your serial number we at Apple will see what we can do.
To obtain your serial number go to settings click general and go to about the first part o the iPhone.  Thank You. Steve A
Dec 22, 2008 | Apple iPhone Smartphone
Iphone touch-screen
sir whats ur model\????
May 28, 2008 | Apple iPhone Smartphone
Possesed phone
Sounds like some sort of short in you keypad, possibly some water or liquid has come in contact with your phone?
You should seek service IMO.
Apr 25, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Continuous redialling of most recent number
there may be some virus attack...
give restore factory settings ... this solves your problem....
Feb 18, 2008 | Samsung SGH-D900 Cellular Phone
Replace Iphone screen with IpodTouch Screen ?
No. They are completely different LCD's and Different Digitizers. An iPod touch's form factor is also different than a iPhones, as the touch is slightly taller, and narrower, I believe. I had a similar precdicament, so I know from doing some studying.
Dec 24, 2007 | Apple iPhone Smartphone
Iphone photos
opened iphoto and it gives "no items to import" ? if true try this. when iPhoto is open and your phone is connected, open the albumn of pictures you've taken with your iphone on your iphone. iPhoto should immediately recognize the new pictures you had taken and should indicate "x items to import." x being number of photos. An alternative to this can be If you individually delete the previously imported iPhone Camera Roll pictures using the trash can on the bottom right (touching the screen brings it up), iPhoto will then see the new iPhone pictures for importing. I believe this can be done without opening at the time of sync the iPhone Camera Roll picture album as you suggested. Give these a try and let me know.
Sep 24, 2007 | Apple iPhone Smartphone
Apple iPhone 3G Logo
227 people viewed this question
Top Apple Cell Phones Experts
Lesley Cameron
Lesley Cameron
Ed Nelson
Ed Nelson
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
