Question about Frigidaire GLTF2940ES Front Load Washer
Will not spin,
Have replaced motor control board, all other cycles work fine ,water wiil drain
  • 435 Answers
Washing machines may drain but doesn't spin because of the following reasons:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Thank You
    Posted on Jan 16, 2009
    My washing machine won't spin when in a wash cycle but will spin on a spin cycle
    ???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
    Jun 09, 2015 | Hotpoint WF430 Front Load Washer
    Washer will not drain on the spin cycle
    since the spin cycle is high speed, you may actually have a problem in the door lock safety switch
    Oct 26, 2014 | Washing Machines
    My Kenmore 300 model # 11028332700 washing machine filled with water and stopped working. It won't agitate, spin or drain. I've replaced with lid switch and checked the coupling and it's fine. What's...
    Possible fault with the water level sensor , it must send signals to the program controller main board to switch on the motor for the wash cycle only when the water level set is reached. Remove the water level controller unit , check the diaphragm with a blow test , it must switch with vacuum , if not replace.
    Aug 22, 2013 | Kenmore Washing Machines
    My wife put a heavy load into the machine. Though the machine spins slowly the spin cycle does not remove any water. Is the motor going bad or is there something wrong with the pump that removes the water?...
    There are two motors- the drive motor for the basket and a seperate drain motor for pumping out water. It there is standing water in the tub it is possibly a bad drain pump or plugged(say a kids sock) If you pull the drain hose slightly up out of the stand pipe while it is draining and there is full water flow your pump is fine. (will not spin with water in tub) (door lock also needs to work)
    There are some out of balance switches on machine to limit speed in spin. Need to manually test.
    The tech sheet is probably in the back of the console controls. To check the main motor involves removing the front panel and the p4(by memory, do not quote me on this) connector on the motor control board in the base. Working on the main motor is more involved, not going to cover all the testing neccessary with just your description of problem. Nice washing machine, but there are easier ones to service.
    Hope this helps
    Jan 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
    I have a Frigidaire front-loading washing machine, model# FTF2140ES3 (serial# XC63816300). It works fine through the rinse cycle, but does not drain or spin. If I turn it to the rinse/spin only cycle, it...
    Hi
    Thanks for using FixYa. Please check the water pump. Either the water pump bearing is bad or there are some tiny pieces of debris stuck in the water pump. It is located below the door latch assembly. Remove the front panel and check the drain pump which is attached with hoses. Remove its clamps and clean the drain pump. You can also remove the drain pump by unbolting it from the washer base. If still the issue persists, then check the motor speed control board which is located inside the bottom of the washer. Please do accept the solution if the issue is resolved or
    post a comment for further assistance.
    Thanks
    Rylee
    Jun 08, 2010 | Washing Machines
    Front loader won't spin, but it washes fine, drains fine
    CHECK THE MOTOR. IF MOTOR GOOD, REPLACE MOTOR CONTROL BOARD.
    BOYNISMO@YAHOO.COM OR 714-334-1998
    Nov 27, 2009 | Frigidaire Washing Machines
    HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
    This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
    When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
    This appears then that is is either the connection to the motor itself or the timer.
    The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
    Sep 09, 2009 | Washing Machines
    Spin speed too slow
    CHECK THE PUMP. I had the same problem and after removing the pump (fairly easy) found a clump of stuffing from a hole in a quilt jammed in the impellor. After removing and installing the then cleaned out pump it worked perfectly. Suggest using a regular stainless steel hose clamp in place of the factory clamp that is hard to put into position on the hose to the pump. Be sure to put the clear plastic bag back in place over the pump assembly to protect the pump from water damage.
    Or the  stater motor on the back has lost a phase because one of the windings has shorted. If the cycle sounds normal and it doesn't sound like it's struggling then the problem is probably not going to be related to the motor. I've found most of these cases to be related to the control board itself.
    good luck
    May 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Frigidaire GLTF2940ES Front Load Washer Logo
    155 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
