Question about Canon PIXMA MP780 All-In-One InkJet Printer
Wron catridge My printer is saying wrong catridge and not printing for some reason this has never happend before and I am using t he same catridge for 15 months!!!
    Sergeant:
  • 174 Answers
How many time do you refiled the cartridge?
Are you change by new one or refile when cartridge get empty.
Replace with a new one.
Posted on Jul 23, 2012
  • 435 Answers
Try to reseat the print head:
Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down thewron catridge - mp780_ph_inserted.gif />mp780_ph_inserted.gif
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tankwron catridge - mp780_inktankclicked.gif.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks inwron catridge - mp780_alignment1.gifave the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, entwron catridge - mp780_alignment2.gif patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
Posted on Jan 16, 2009
What are three possible causes for a printer to not print?
Hello, * The first reason has to be the Catridge without ink. * The second reason has to be Catridge not fixed properly. * The third reason it has to be problem with the Paper slider getting stuck because of dirt and dust.
Nov 02, 2010 | Canon imageCLASS D320 Laser Printer
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Using generic cartridge
does the pop up stop the printing
there is nothing wrong in using generic brand catridges
Dec 30, 2009 | HP Photosmart C5180 All-In-One InkJet...
I refilled the catridge it doesn't print
you have to clean and reset the cartridges. clean also your cartridge socket or holder.
Sep 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer will not print colors
Printer not print colors. possible reasons....
  1. your color catridge may be empty.
  2. Your color Catridge may be jam.
  3. your color catridge may not be properly installed.
Thanks
Aug 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp 1410 print problem
Try reinstalling your printer driver again.
Jun 09, 2009 | HP PSC 1410v All-in-One Printer
Red colour toner replaced Cartridge with a new onebut still no print coreect. Replaced the Yellow colour toner Cartridge with a new one but printing is not clear.
this problem regards the head of the catridge. u have to do clean due to dust it may happenlike that. u clean inside with the cotton cloth on the print head and refix the all color catridges. when u remove ur catridge u have to close all the sides due to avoiding dry.
the second reason when u purchase ur catridges, check whether the catridges are valid date.
Apr 16, 2009 | HP LaserJet 1600 Printer
Blinking power light
It could be the timing of the cartridge is out possibly from the belt.
It should be serviced by a technician.
Jun 16, 2008 | HP Deskjet 3845 InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
287 people viewed this question
old marine
old marine
