Question about Whirlpool GMC305PRS Stainless Steel Electric Double Oven
Oven Microwave combination acts crazy
I have a Whirlpool GMC305PRS01 combination that is acting eratic with no error code. It scrolls thru the quantity selection and sometimes the oven comes on by itself. I can stop everything by holding the microwave stop button but it starts again when released. I live in Mexico and there is no qualified technicians available here.
  • aussiemic711 Jan 19, 2009
    Is this something I can replace myself or do I need someone who knows what they are doing? I have a lot of do it yourself experience but not much when it comes to electronics.
    President:
  • 2,110 Answers
Try putting it into CLEAN MODE and wait about 3 minutes.... then cancel the clean mode. Sometimes this will release the relay if its stuck.
If that doesn't work, you have a problem with the latch relay and you need service on the unit. You can try and remove the latch assembly yourself, but it can be tricky, and you may create more problems than you fix.
Posted on Jan 17, 2009
    Sergeant:
  • 378 Answers
The contol board having short in its circuit and needs to checked and repaired or may be replaced if major problem
you can get the required parts at
www.repairclinic.com
    President:
  • 1,990 Answers
Welcome to Fixya! This is a Problem with the Main Circuit Board and will have to be Replaced. Since there are no Service centers there You may want to Try and Find this Board Online. The Manufacturers Website has a Parts List for this if you go to Customer Service.
  • Travis Humphries
    Travis Humphries Jan 19, 2009
    I would Definatelly have it Repaired by a Pro. There are a Lot of things that could go Wrong in this situation.
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
Whirlpool oven is "locked" -
Hello & Welcome to FixYa
F2 error code indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Sep 02, 2011 | Whirlpool Ovens
This KitchenAid combination wall oven and microwave unit was purchased in 2002. Except for having to replace a fuse in 2004, it worked fine until the microwave started acting up recently. In September...
Good Question. I work on all brands of appliances, and I swear by KitchenAid-Whirlpool appliances. That being said, I do not recommend oven-microwave combinations, because the ovens will last 30 to 40 years, but the microwaves start having major repairs from 6-10 years on. I would bite the bullet and put in a separate Panasonic microwave (with an inverter) and a seperate KitchenAid Oven. You also need to install a 2000 Joule or higher surge protector, for your microwave oven. Panasonic microwave ovens are better than the KitcheAid ovens at this time.
I would suspect that the touch panel-control board failure may have been caused by the repairman, just because the timing is a little too close to the mag repair. No way to tell you for sure, and I myself have had control board failures the same day that we changed a light bulb, so anything is possible. Usually a factory defect is going to show up before 8 years. In the last 4 years in the greater Seattle area, 70 - 80% of our business is from power surges hitting the electonics in the different appliances, so this could also have been what has caused your repairs. On a 240 volt Oven, the only way to protect it from power surges is to have a whole-house surge protector installed on your house electrical panel. You still need to have individual surge protectors, above 2000 joules, for your appliances that are 120 volts. Good Luck, Appliance Specialists
Dec 09, 2010 | KitchenAid Architect® KEMS378S Electric...
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
Microwave on counter making wall oven change
ok the microwave has magnetic fields that may be messing it up only way is to turn microwave off or move it at lease 1 meter away from oven let me know how that goes's for you
Dec 30, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Double oven will not work sometime
Mobley, F2-E6 code is cancel key drive line open. The tech sheet I have on this recommends reseating the keypad connector. It then states to press cancel. If the error comes back within 60 seconds replace the keypad....Catriver..post back.
Sep 16, 2006 | Whirlpool GBD307PD Electric Double Oven
Whirlpool GMC305PRS Stainless Steel Electric Double Oven Logo
54 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De GO PATS
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
