Question about Panasonic Lumix DMC-FX2 Digital Camera
My LCD screen went dark
My display LCD screen just went dark. It's not the power save, and I've tried to adjust the brightness as well. I can still see images but it's very dark as if the backlight bulb is broken. Hope this is clear. Thanks
  • George Yaryura Jun 19, 2007
    The correct model is DMC-FX9 6M pixels. Couldn't find it in the listing
  • Anonymous Jan 03, 2008
    This is probably problem with power tape - not so easy to fix, but possible. email me at: phew (@) o2.pl
  • 53 Answers
It sounds like somehow the light in the LCD has shorted out. You probably need the LCD screen. If you need some parts you may want to contact a guy in South Carolina who has lots of used parts for all the Panasonic Cameras at reasonable prices. I bought a used LCD from him and it works like new. I think his email is [email protected]
Posted on Mar 12, 2008
Nah i havnt found a solution, i think ill just giv it into the service center
Posted on Jun 20, 2007
    Genius:
  • 2,985 Answers
Well looks like you sussed the problem - no backlight Can it be fixed? -I doubt it, unless it is failry new and warranty comes into play Give the Panasonic website Techincal Support Team a look E-mail the problem
Posted on Jun 19, 2007
SOURCE:
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
Tip
How to save power even you are still using old VGA Monitor
Older monitors(CRT type) are using complex circuit than LCD, It requires more power consumption than LCD, but you can still save power by 30% through this tip.
1.You must position or install your monitor in a dark area or position.
2.Adjust the brightness control to the level of the black part of the picture must be seen black not gray, or became white.
3. Adjust the contrast control at your most comfortable level.
4.Avoid using bright picture screen saver or blank screen saver.
5.Turn off your monitor manually if necessary.
on Jan 19, 2010 | Computers & Internet
My screen is very dark ...cannot adjust brightness...
Hi, if it is very dark to the point that it is almost black and has no light at all then there is a part in the display needs to be replaced, it is called fl tube. if the screen is dark but still there is somewhat some light then try going into the power setting, your pc might be set for low brightness to reserve power, see if you can adjust there, otherwise your display may just be going bad... Best of Luck
Jan 30, 2011 | HP OmniBook 6100 Notebook
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
Vaio laptop- screen went dark but is still on.
check power from adapter, if its ok, try looking at your function key and adjust brightness through function key. or else you might have to replace the lcd bulb....
Feb 18, 2009 | Sony VAIO PCV-W20 PC Desktop
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
Screen went dark (almost completely)
check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
Dec 12, 2007 | Dell Inspiron 6000 Notebook
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Panasonic Lumix DMC-FX2 Digital Camera Logo
897 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
