Question about Philips 60PP9352 60" Rear Projection Television
I have projection TV 55PP9363H/17 SOUND NO PICTURE.
Hi have a Philips projection screen TV model # 55PP9363H/17. The problem I'm having is the unit power on I get sound but no picture. I open the unit begin doing voltage check. Notice the flyback isn't oscillating.Check horizontal output and drive Transistor check ok.No HV going to the CRT, No screen volts. Filiment light up on all three CRT. I change the flyback the same problem continue. Is there anyway you can assist me with the above issue? Thank you.
    President:
  • 3,130 Answers
Check the horizontal output transistor, it could be open.
Posted on Jun 19, 2007
SOURCE:
Bulb out in a Phillips model #55PP9363H/17
you can get a bulb at ( discount-merchant.com) these guys are pretty good as far as availability. prices are also reasonable.
Mar 29, 2010 | Philips 55PP9363 55" Rear Projection...
I'm looking a HD cable.
This set may have a DTV cable. You probably have an HDMI cable on your box. You can get a DTV to HDMI adaptor.
Nov 23, 2009 | Philips 55PW9363 55" Rear Projection...
Picture is doubled and multi-color
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 20, 2009 | Philips 55PP9363 55" Rear Projection...
Sound but no picture
Common problem - Its most likely the HVG on this model. www.TvRepairKits.com has instructions on how to get it fixed.
Apr 17, 2009 | Philips 55PW9363 55" Rear Projection...
Craked screen
You can find a new OEM Philips replacement lenticular screen and Fresnal screen for a model # 55PP9363H17 from a major Philips distributor at the following links:
Philips 55PP9363H/17 Replacement Part Lenticular Screen
Philips 55PP9363H/17 Replacement Part Fresnal Screen
And here's a link for the protection screen if needed:
Philips 55PP9363H/17 Replacement Part Protection Screen
Apr 02, 2009 | Philips 55PP9363 55" Rear Projection...
SOUND BUT NO PICTURE
is it nothing on the screen at all? if so your projector bulb blew. they usually cost a coupole hundred bucks
Mar 07, 2009 | Philips 60PP9363 60" Rear Projection...
Need screen replacement
try www.tvscreenprotectors.com they either have or can find you a replacement screen
Mar 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
Unit power up have sound but no picture.
Check the damper diode and the protection resistor in the High Voltage circuit. Good Luck.
Jun 18, 2007 | Philips 55PP9363 55" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
240 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
