I have a HpPhotosmart C4280 all in one --Problems copying
The copies are blurred and sometime double prints -- Is it possible to get a ''USERS' MANUAL'' I did not get one with mine?
    Novelist:
  • 297 Answers
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Printer is making 2 copies instead of the requested one
when you go to print a page, click page setup, and change setting for copy's from 2 to 1...shia
May 22, 2009 | HP Photosmart C4280 All-in-One InkJet...
Can I fix this stuff without a service call?
black spots can also be caused by drum...
developer normally will cause blur print due to developer uneven or dirty (dust)...
Apr 17, 2009 | Office Equipment & Supplies
Windows keeps re-installing HP Photosmart C4280
I have a customer with Windows XP and the same issue. Told him to unplug the printer cable when starting the computer and/or restarting it. Wait until all auto-start programs have loaded, including and specifically the HP Monitoring Utility program. Once Windows is up and he's at the desktop, THEN plug the printer cable into the computer. He's been doing that for several days now with no duplicate printers installed.
Mar 13, 2009 | HP Office Equipment & Supplies
Double vision
If you are printing color and you have color blurring like streaks. it mean the registration of the colors are off. Usually using the internal cleaning function from the panel will clear this up. You should restart the copier as well. If it continues check all the feed rollers.
Feb 12, 2009 | Canon imageRUNNER C3220 Color Copier
How to get glowing effect in coreldraw
To create a glow: make a copy of your image you want to glow. paste to the side or original. select original. Convert to Bitmap, then use Gaussian blur, select pixel width of blur, preview it, then apply it when it look good. Put your copied image on top of the blurred image, bringing the copied image TO FRONT. voila NOTE change color of image to be bit-mapped BEFORE you convert to bitmap for a COLORED Glow
Dec 19, 2008 | Computers & Internet
Hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Nov 24, 2008 | HP LaserJet 1600 Printer
jasbo
jasbo
