Question about Gaggia Titanium Espresso Machine
Grinder spins but won't grind coffee
The grinder on my Gaggia Titanium will spin, but won't grind any coffee into the doser. I keep getting "out of coffee" message with a full hopper. I have poked around enough to be sure that the beans are not clogged in the chute, it just won't grind anything. Can anyone help? Paul
  • 3 more comments
  • melville1996 Nov 16, 2008
    i dont understand the answer give, i have a gaggia, that keeps telling me that i need more coffee beans. it clearly grinds but the beans are maybe not getting down to the grinder?
  • Anonymous Mar 18, 2014
    Getting weak brew
  • Anonymous Mar 26, 2014
    spills out coffee grinds
    grinder clogged
  • Anonymous Mar 29, 2014
    The coffe beans will not grinds
You have fill a water in your coffee grin
Posted on Jul 17, 2007
2 Suggested Answers
SOURCE:
  • 20 Answers
SOURCE: The grinder on my Gaggia Titanium will spin, but
Does it sounds grinding beans or free spinning sound?If free spinning sound...Grinder mechanism is broken.
Posted on Dec 16, 2009
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
Tip
Rancilio Rocky w/ doser: clean sweep of coffee grounds
The Rancilio Rocky coffee grinder is a superb, highly recommended machine, but its doser is pretty useless in the home. First reason: you want to grind coffee instants before you brew or pull your espresso shot; otherwise, the grinds just lose aromatics and flavor. The doser only works for multiple doses, so you're better off just grinding the amount you need each time. If you're buying a Rocky, get the doserless model.
If you have the doser model, like I do, you also find that the vanes which sweep the coffee into your portafilter or cone leave a layer of grounds on the doser floor. If not cleaned out, they turn rancid. There are coffee web sites with fairly complicated instructions on how to modify the vanes to do a clean sweep. Here's the simple way:
Flip up the doser cover, and spin the vanes while pressing your finger lightly on the outer top edge of one vane. The vanes have enough play so the pressure brings one into light contact with the doser floor, sweeping 99% of the grounds into your waiting portafilter.
on Jan 03, 2011 | Rancilio Rocky Espresso Coffee Grinder -...
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
Tht grounder doesn't work, it say's coffee beans empty, even if there are...
Turn the big knob to the biggest number and the small knob the the -, then try again. You are getting a clog in the passage from the grinder to the doser because your grind is to fine. If it clears trun the big knob back to a number higher than you had before and the small knob to the position you had. Only turn the bigh knob to a smaller number when the grinder is moving. If this doesn't work you will have to clean the grinder and passages with a vacuum.
Oct 26, 2010 | Gaggia Titanium Espresso Machine
New grind and display shows "grinder blocked"
This normally indicates due to the grinder being set too fine or oily beans being used.
Try setting the grind on 7 .
If it still fails the grinder will need to be unblocked and serviced.
Dec 07, 2009 | Gaggia Titanium Espresso Machine
Gaggia Titanium integrated grinder not spinning, not grinding.
your grinding chamber is blocked, the same happened to me, did it struggle to grind before? try taking the black shoot out the top with the 2 screws( were you would put pre ground coffee in) take the brew unit out(along with the waste water and bean tray), and reach up to where there is a little spring, the spring controls a little door, if you open the door manually and clean out the shoot to the grinder( make sure the machine is unplugged for this), i used the end of a tea spoon and a little hoover. it should work after this
Mar 18, 2009 | Gaggia Titanium Espresso Machine
Gaggia Titaminu
check to make sure the blades are secured to the motor shaft. some have a set screw, some are positioned over a pin in the motor shaft.
Sep 10, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
867 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
