Need a manual for programming a behringer acx ultracoustic 1000 or web place where we can download it
  • mercenarygui Mar 02, 2009
    need a manual for programming
    Genius:
  • 1,175 Answers
Http://www.behringer.com/EN/Products/ACX1000.aspx
Posted on Jan 18, 2009
Where do can I get a copy of the schematics.
https://elektrotanya.com/behringer_acx1800_sch.pdf/download.html
You can download 2 manual per day, else you have to take & pass the electronics test :-)
Feb 21, 2016 | Behringer ULTRACOUSTIC ACX1800 2x8...
Is the right output transistor part number the same as the left output transistor.
Should be provided you only have a single transistor in the output power stage. If you have a pair of transistors in push pull arrangement, then those two units for that one individual channel will be different.
Sound dies off gradually for a second or two, then comes back. This happens often. Thanks.
It sounds like there is a thermal problem. If you can't make it happen by shaking, or banging on the amp. If it comes and goes with the shaking and banging then there is some loose connection.
If you still have trouble we here at Pro Line Music have a service department and can repair it.
2157368055
May 27, 2011 | Behringer ACX450 Ultracoustic 45 Watt...
I have just bought a behringer vmx 1000. I have a sony stack system can you tell me how to connect it up, e.t.c what cables go where. Thankyou
IAW its sparse manual which apparently assumes some hi-fi experience on the part of the user...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Behringer-VMX1000-manual/id/23281bh548/t/2/
Success will depend on your "stack" systems capabilities.
May 13, 2011 | Audio Players & Recorders
Berhinger acx 1000, power on, no sound amp not working, everything lights up on display but no sound or amplification
Just had the baby brother (ACX450) with this problem...opened the amp... screws from sides and or top (including 2 hidden under handle covers).
The power cable from the power transformer had come off the connector on the circuit board in spite of goo they had put on it. Put connector back on and secured the cable and works perfect,
Since your display lights, yours is likely a different problem. I have also seen similar ones that the cable to the speaker had been pulled off its connection on the circuit board, rendering no sound. See if you have sound at headphone jack. and if none, how about the preamp output jack? Note you will only hear the left side using earphones as these jacks are monaural.
Feb 06, 2011 | Behringer Ultracoustic Acx900 Acoustic...
Humming sound ACX 1000 ultrasound. humming sound is continuous even though nothing is plugged in to amplifier, (ie;No instruments )qrjc@bigpond.com
try unplugging cables from the inputs, one by one and see if the hum stops. If it does its a ground loop, if don't it could be a leaky filter capacitor in the power supply
Mar 08, 2009 | Behringer EUROPOWER EP2500 Amplifier
Connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
Aug 08, 2008 | Phonic Audio Players & Recorders
 Grubhead
Grubhead
