Question about Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size Gas Dryer - Arctic Blue/Chrome
Maytag Epic gas dryer won't get hot
Takes hours (literally) to dry a load of towels. Sensor timer never gets to zero. Goes down to 5 minutes and then jumps to 51 minutes or 99 minutes, apparently "sensing" just how wet everything is.
  • palmedward Feb 08, 2009
    Maytag EPICz gas dryer isn't drying using the sensor feature, not even close. Just had it delivered last week (1/31/09). Using the timed side is OK, but we spent the extra money for this unit expecting that the sensor feature would prevent shrinkage, etc. The Sensor dry choices just haven't worked at all after about 10 loads, using different sensor settings, etc. Anyone else have this issue?
  • Anonymous Apr 26, 2009
    Maytag Epic Z (electric) won't dry. Acts like it is, but no heat and things are wet. Sensor counts down and then jumps to 99 and begins again.
5 Suggested Answers
  • 213 Answers
SOURCE: Maytag LDE412 Dryer
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
Posted on Nov 26, 2007
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
  • 94 Answers
SOURCE: Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Posted on Oct 14, 2008
  • 5 Answers
SOURCE: maytag gas dryer taking too long to dry clothes
Not too familliar with the gas temp either, but you should definitely take your lint filter out and clean it with soap and water. If you use dryer sheets, they can leave a clear film on your filter and it can be just as bad as a filter full of lint. Try this out, if it works, clean your filter periodically with soap and water to remove the chemical buildup.
Posted on Apr 13, 2009
tshot2020
  • 16 Answers
SOURCE: NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Posted on Apr 20, 2009
Maytag epic electric dryer takes a long time to dry clothes
check your vent by removing the vent from the back of the dryer run a normal load in the dryer and if it runs normal you have a crushed vent hose or it is plugged somewhere
Nov 17, 2013 | Dryers
My dryer does not shut off and doesn't get hot. It takes almost 5 hours to dry a load of clothing.
Sorry to say but it sounds like the heating element is on its way out... Happened to ours and repair was more than a new dryer so we brought a new one
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
3 BATH TOWELS AND ONE HAND TOWEL WERE NOT DRY AFTER 60 MINUTES IN DRYER . THIS HAS BEEN A PROBLEM SINCE WE BOUGHT DRYER IN MAY. A LOAD OF UNDERWEAR, T SHIRTS AND SWEAT SOCKS ALSO WILL NOT DRY IN AN HOUR...
HI,
If the unit is less than a year, you problem is a restricted vent system and not in the unit either. A simple test would be disconnect the vent from the back of the unit, run the dryer. If your clothes dry faster, your problem is in the vent system. If no improvement, problem is in the dryer. Get back to me and let me know how this goes.
Thanks
Aug 09, 2011 | Maytag MDG2706A Gas Dryer
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Isn't heating up. takes forever to dry,
Disconnect the complete exhaust vent tubing and clean it out thorourghly. Then it will dry. There is a moister sensor in your dryer and when the lint builds up inside the vent tubing the sensor shuts off the burner to prevent fires from starting
Apr 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Maytag gas dryer
the glow plug sensor not accurate send to timer /replace sensor
Nov 30, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Maytag LDE412 Dryer
Nov 26, 2007 | Maytag MDG7600AW Gas Dryer
Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size Gas Dryer - Arctic Blue/Chrome Logo
116 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
