Question about Brother IntelliFAX 560 Plain Paper Fax
Document jam i am getting document jam error I have cleaned machine out and still get error
    Champion:
  • 320 Answers
THIS SOUNDS LIKE YOUR PAPER JAM KNOCKED OUT A PAPER SENSOR IN THE PAPER PAPER! PLS CHECK FURTHER OR YOU WILL HAVE TO GO TO A SERVICE CENTER BROTHER TECH
Posted on Jan 19, 2009
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
What does coms error 00E8 mean?
Canon FAXPHONE L120 Laser Printer Please follow the instruction as given below may this will help u any
Error Codes
An error code is a four-digit code displayed on the LCD or in the bottom row of a TX Result Report or an RX Result Report when an error occurs.
See the table below for individual error codes.
Error Code Description Action 0001 The sender may not be using a G3 fax machine. Make sure the sender's machine is compatible with your machine 0070 Reception was manually canceled on the machine. Ask the sender to resend the document if necessary. 0071 The machine's memory is full. Print, send, or delete any documents stored in memory. 0080 The recipient's machine did not respond within 35 seconds. Resend the document. Ask the other party to check their machine. If you are making an overseas call, add a pause to the number. 008D The recipient's machine has run out of paper. Ask the recipient to make sure that paper is loaded in their machine. 00A0 Transmission was manually canceled on the machine. Resend the document if necessary. 00A1 There is a document jam. Clear the document jam. 00FF All redialing attempts have failed. Check if the recipient's number is correct or the telephone cable is properly connected, and try again.
Aug 18, 2010 | Canon L120 Fax Laser Printer
My Canon MP530 indicates that I have a paper jam. There is no paper jam - I have checked and re-checked and turned it off and on several times and it is still reading that there is a paper jam. How do I...
Hello there You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 25, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Machine reads "document jammed"
its the problem of the rollers which pulls the papers they r worn out.I've seen this before repairing computers and asked about fax machines while I am there. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Document, Jam???
Hey I figured it out. On the top where you insert paper into the automatic document feeder you will notice a small switch. When paper is set in the tray the switch is pressed down. I noticed on mine that the switch had become stuck down. I just used a small push-pin and popped it up. Error message went away.
Feb 01, 2008 | Brother MFC-8460N All-In-One Printer
Brother intellifax 2820
There is a black sensor arm in the rear of the machine just out of the fuser unit (hot section) on a black cover. It can become dislodged. Check this will read a false jam.
Jan 12, 2008 | Office Equipment & Supplies
Sharp F0-1460
"DOCUMENT JAM" refers to your original document that you are trying to send. Lift the top of the Automatic Document Feeder (ADF) and look for a tiny peice of torn paper. If not, look for a stuck sensor flag (might look like a small plastic finger). If still no go, clean the roller that feeds the original, it may be worn out and slick. Hope it helps Ed
Jul 13, 2007 | Pitney Bowes 9920 Plain Paper Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
162 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
