I brought this dvd burner 3 months back. problem rise when i burn some of my first's dvds. I made data dvd. when i read after burning. It shows contents on one of two cd and nothing on second. Today i again try to read that dvd on my dvd player and magically after take some load on window it read that unreadable dvd But after sometimes it again shows it blank. i have 512 ram 2.8 dual core processor. I already send this dvd to company for repair they say dvd work fine. my friends laptop and dvd player read those dvd fine. But also i Face this problem in world. please help. What can i do for this problem.
It sounds to me like it is one of two things. More likely that you are using a very low quality DVD. Yes there is a difference in the media that you put in and too cheap is just that, cheap. Not all the dyes that are put into a disk are equal. You can try to buy better name brand disc and try that as well.
The other possibility is the that you are not finalizing the disc once it's been burned. I've noticed that on Nero the defaults tend to favor multi-session discs and use "write at once" instead of "disc at once." So try using the disc at once feature or finalizing the disc to see if that helps. I know that some legacy drives have a hard time with multi-session discs still.
I hope that helps. I know my Sony drives works great and I've been very happy with it.
Was this helpful?
Yes
No
Popular Solutions for Sony AW-Q170A-B2 DVD RW Dual
my dvd drive isnt reading original dvdsit reads them for the first time but after a few days it does...
(More)
my dvd drive isnt reading original dvdsit reads them for the first time but after a few days it does not read it there are no problems with the disk as i have checked them on my neighbours pc
my sony dvd rw drive AW-Q170A cannot read the dvd's i put in it. in the properties of the dvd it...
(More)
my sony dvd rw drive AW-Q170A cannot read the dvd's i put in it. in the properties of the dvd it shows free space- 0 bytes and used space- 0 bytes. what should i do to fix the problem?
I turned on my PC from Windows Vista to Windows XP.The PC works perfectly but I can't connect to the...
(More)
I turned on my PC from Windows Vista to Windows XP.The PC works perfectly but I can't connect to the internet.What's the problem?What can I do to solve this problem? Sincerely,Bruna
Using Cyberlink Power producer I have made DVD of home pictures. Will play on my other standalone...
(More)
Using Cyberlink Power producer I have made DVD of home pictures. Will play on my other standalone DVD players but not on my new Sony RDR-HXD890
