Question about ASUS M2N-MX Motherboard
M2n-mx se problems
My browsers crash (mozillia and IE) mozillia mostly and sometimes the computer will shut down all by itself and reboot i have downloaded driver and stuff becouse i dont have the original discs i have reinstalled windows and used the ones i downloaded according to what spec are on the motherboard but no luck browsers still crash and i have no sound
  • 44 more comments
  • sandman19751 Jan 16, 2009
    Thank you i tried that and it still didnt work right
    i tried updating through my computer didnt help and i use them both and the problem mostly happens when its been off awhile and when u use mozilla it will crash or restart computer after that it works ok on a restart normally works ok
    when i reinstall windows the first thing i do is the chipset then audio i also have other computers hook up and they work fine its just this on we have had for about 3mths it crashed bad wouldnt let me into windows so i reinstalled windows and i have had a problem ever since
    a new error came up today it says programs cant open files on the hard disk could this be the main problem with the comp crashing
    ok how would i fix it if it was my drive
    and how do i get to the windows error log
    ok were do i reinstall the zip files for the chipset and stuff into c: drive and does it matter where plz i need step by step instruction here
    windows xp cd right and what would i do to reinstall windows step by step if i have to
  • sandman19751 Jan 17, 2009
    and can anyone tell me if the ones i have are correct
    Nvidia_Chipset_Raid_v6533_32bit
    Realtek_ALC662_Audio_V51005377_V6015384
    AMD_v1320
    ASUS_CoolnQuiet_V21706
    when the zip file extractor comes up where do i unzip them into specific files plz
    none of them picked up after i redid windows this is a fresh copy of windows and im still having yhis problem im thinking the drivers arent in the right place
    or is it possible that the zip files i downloaded are missing files
    ok when i do a format the deletes windows and reinstalls it right
    ok when i reinstall windows do i need to install a third party sata or raid driver and the lastime i did it it didnt go right to format it said windows couldnt install it then promted me to go back to the partition page then i went to install a fresh copy again and it went
    ok when i get windows back do i install complete chipset or just network contoller
    ntsf quick or the other option
    ok im going to start install now
    ok its 18% into formatting and i did not do quick
    ok something popped up about setup cant copy the file:msports.inf what do i do
    well i skipped that file and went on with install
    it says it cant copy msrclr40.dll either
    nvm it went thru with the dll file
    thats not going to hurt anything
    ts still going thru setup and its still not being able to copy files
    its in its last stages of install it says 9min
    why was it skipping files it hasnt done that before
    its still on finalizing installation
    yes but ia, missing alot i cant even put in .net framework
    no its not under warrenty and i think im going to reinstall windows again if this dont work
    no this problem happened after windows crashed wouldnt even load windows at all so i reinstalled windows and been having problems ever since
    could it be the windows disc im using
    ok im reinstalling windows with a different windows disc
    i edo windows on my other comps all the time and never have this much trouble
    this disc is formatting faster than the other one
    what type of books can i get to help me understand windows better and learn how to take care of stuff like this myself when it happens
    well it didnt skip files this time im at the installing windows page lets see how it goes
    OK WHERE DO I EXTRACT THE DRIVERS TOO
    THE ETHERNET DRIVER IS IN THE CHIPSET ZIP FILE
    NO I DIDNT
    c:\windows
    ok ty
    ok my display driver isnt working the page has like a ripple effect
    ok nvm it has stopped it seems to ok at the moment
    yes but it seems a bit sluggish on page load
    but i had mozilla running on it before
    ok ty i will definatly be back here if i have more problems
    my yahoo is sandman1975111 i think anymore problems would be easier on there
    Scholar:
  • 58 Answers
Hmm, you are talking about drivers, browsing and sound.
First of all. When you reinstall your computer you always install the chipset driver first. In your case the nvidia chipset driver
Sometimes when you install an audio driver it is not recognized if you don't install the chipset driver first.
after this you can choose to install the audio driver first or the network driver.
According to the Asus site your motherboard has a Realtek HD audio. In this case except from the realtek driver you will need the uaa driver. Universal audio bus driver.
you need to install the uaa bus driver first and then the realtek audio driver. This is a known issue of microsoft.
this is the link
http://support.microsoft.com/kb/835221
unfortunatly for me it is in dutch maybe for you in english.
there you can find more info. that should help the audio.
If you installed these drivers and your network drivers and your browser still crashes you can try 2 things.
verify with another computer or laptop if your router/modem is working correctly if yes you might have a problem with your onboard network driver.
My suggestion would then be to buy a cheap network card with drivers, install it and test if you still have the browser errors.
With my Asus P4g8x deluxe motherboard there was a problem with the onboard network and solved it in that manner because it was older then the guarantee.
Hope this will help you in some way.
good luck.
Posted on Jan 16, 2009
  • goovy75 Jan 16, 2009
    In that case i would also check you windows error log if you find a lot of errors on your disk. If you have it could be very likely your drive.
    Genius:
  • ASUS Master
  • 1,102 Answers
Make sure your os supports mozilla foxfire
you may want to uninstall foxfire for a few days and see what happens
  • 34 more comments
  • DEKR
    DEKR Jan 16, 2009
    update your driver for sound through my computer properties and what antivirus do you use
    have you installed foxfire
  • DEKR
    DEKR Jan 16, 2009
    are you trying to use foxfire and IE
  • DEKR
    DEKR Jan 16, 2009
    try lookin in your my computer properties hardware then device
    i would scroll and see if i have anything with a ? or ! mark if you do then update
    if not i would reinstall my windows doubt you need a new network card if system is only 3 mnts old
  • DEKR
    DEKR Jan 16, 2009
    i would reinstall the os systems i think your missing some files
    save any important files
    then reinstall by booting with the os cd
  • DEKR
    DEKR Jan 16, 2009
    reinstalling will probably correct your problem
  • DEKR
    DEKR Jan 16, 2009
    after install i would'nt download fox fire unless i had to
    if you are just booting from cd on a restart you should not lose your chipset or other info
    just make sure you go to my computer property and devices right down audio
    video and network connections
    put your cd in and restart from cd
    if you don't have the option to boot from cd
    restart and continuosly press f7 when box appears click boot from cd then restart with cd in drive
  • DEKR
    DEKR Jan 17, 2009
    don't forget to check and see what your drivers are and right them down
    once you boot from xp cd it's going to give you options
    make sure you delete selected drive then it will ask you for delete confirm make sure you do the confirm then it will delete and make new selected drive then click enter follow instructions
    make sure ethernet is plugged in so it can pick it back up
  • DEKR
    DEKR Jan 17, 2009
    i believe they are correct
    they should automatically pick up
    if not i can help you add them
  • DEKR
    DEKR Jan 17, 2009
    they could be miss placed
    but i think your missing files
    i would still do a format you can add the drivers and i can help you with that
  • DEKR
    DEKR Jan 17, 2009
    yes it does
    and windows is what i think your files are missing from this happens sometimes on a new install
  • DEKR
    DEKR Jan 17, 2009
    no do not install raid or third party
    that may be why some files did'nt correctly install
    when it shows selected drive make sure you delete that drive then when asked comfirm by pressing letter it indicates then it will return after deletion and then click enter to continue setup
  • DEKR
    DEKR Jan 17, 2009
    we'll see after install
    you'll install your audio video and network adapter
    you should'nt need to install chipset
    it will be there
  • DEKR
    DEKR Jan 17, 2009
    no not quick cause you want anything bad to be formatted
  • DEKR
    DEKR Jan 17, 2009
    then just follow instructions do not press f6
  • DEKR
    DEKR Jan 17, 2009
    i mean don't press anything for raid or third party
  • DEKR
    DEKR Jan 17, 2009
    when you get those just skip
  • DEKR
    DEKR Jan 17, 2009
    okay i'll be back in 1/2 just let setup run
    we'll get your drivers when it's done
  • DEKR
    DEKR Jan 17, 2009
    has it finished finalizing
  • DEKR
    DEKR Jan 17, 2009
    something is really not right
    is this still under warranty
    let it go fo a bit longer
    have you had problems since you brought it home
    too bad you did'nt live by me it would be a lot easier if it was in front of me
  • DEKR
    DEKR Jan 17, 2009
    how is it goin
  • DEKR
    DEKR Jan 17, 2009
    good
    then we'll check out your drivers
  • DEKR
    DEKR Jan 17, 2009
    GEE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
    Hope evrything is okay I gotta hit the sack 3am
    I'll be back online tomorrow if you need anymore help
  • DEKR
    DEKR Jan 17, 2009
    remeber you should'nt need to touch chipset or stuff like that at all
    and don't install mozzilla yet if ya don't need to
  • DEKR
    DEKR Jan 17, 2009
    if your windows is now on right click my computer properties then hardware and devices
    see if your network is ther and audio and video
    if anything has a ? or! click it and update
    if you don't see your drivers showing i'll tell you how not get them
    you wrote them down so it won't be hard
  • DEKR
    DEKR Jan 17, 2009
    control panel
    add new hardware
    click already installed
    then next
    scroll till you find network click and follow instructions
    choose from a list then I doubt you'll need to extract
    see if the driver is in that list first
    if your driver for network is'nt there let me know
    did you already check in properties device if it's in there then you don't need to do these steps
  • DEKR
    DEKR Jan 17, 2009
    if you did'nt see your video or audio
    then do the same thing for them
    control panel add hardware
    next already installed
    then follow steps
  • DEKR
    DEKR Jan 17, 2009
    okay whats up
    did you find your ethernet driver
  • DEKR
    DEKR Jan 17, 2009
    your ethernet when you extracted them before where did you save them
  • DEKR
    DEKR Jan 17, 2009
    control panel add new hardware
    scroll till you see network highlight
    then next
    you'll be given an option to automatically detect
    you can do the same to get your audio and video for them you can choose from a list since you know what drivers they are
  • DEKR
    DEKR Jan 17, 2009
    if you can't get network driver from add hardware
    I would unzip to the same folder there in or to program files
    still don't download mozzilla we'll see how this runs for you first
    IF YOU HAVE ANYMORE MORE PROBLEMS I'LL BE ON TOMORROW
    I'll want to know how it's goin
  • DEKR
    DEKR Jan 17, 2009
    if your still havin ethernet problems tomorrow i can send you your driver
  • DEKR
    DEKR Jan 17, 2009
    yes c/windows program files
    how is everything going
  • DEKR
    DEKR Jan 17, 2009
    so your up and running or do you need more help
    sometimes mozilla is'nt compatible
    so leave it off for a bit
    are you on the internet now
  • DEKR
    DEKR Jan 17, 2009
    okay do a windows update
    also update internet explorer to 7
    then if everything runs okay then download your mozilla and if things start goin haywire again after mozilla then uninstall it
    don't forget to rate me
  • DEKR
    DEKR Jan 17, 2009
    if you click on a search for cprogramming
    you''ll learn a lot about the pc
    I would'nt buy books off the internet
    I do searches on what I want to know and then I print them and keep them in a folder
  • DEKR
    DEKR Jan 17, 2009
    yes your right
    anytime
I WANT TO DOWN THE D RIVER
Hi! Welcome to www.fixya.com.
You can go to this website and download the motherboard driver (ASUS M2N-MX Motherboard)
http://drivers.softpedia.com/get/MOTHERBOARD/Asus/Asus-M2N-MX-SE-Chipset-Driver-6533.shtml
Thanks for contacting Fixya. Bye for now.
Jul 23, 2011 | ASUS M2N-MX Motherboard
My motherboard cd of asus m2n mx se series nvidia is broken so
You can call Asus and buy a new CD at 1-812-282-2787 US.
Or you can download the drivers directly from Asus and burn the drivers to CD/DVD-ROM disk. Link to Asus motherboard M2M-MX SE;
http://www.asus.com/Search.aspx?SearchKey=m2n-mx%20se
Cheers'
Mike
Mar 26, 2010 | ASUS M2N-MX SE Motherboard
I have a problem with audio of Asus M2N MX SE mother board
you can click
http://www4.dealtime.com/xPF-ASUS-ASUS-nVidia-nforce430-GeForce6100-M2N-MX-SE-Motherboard-Retail-Free-Shipping
Jan 07, 2010 | ASUS M2N-MX Motherboard
Installer of M2N-MX SE PLUS motherboard
Hi bud , Follow the link attached for your MB Chipset Drivers http://drivers.softpedia.com/get/MOTHERBOARD/Asus/Asus-M2N-MX-SE-Chipset-Driver-6533.shtml
Have a great day
Sep 20, 2009 | ASUS M2N-MX SE Motherboard
Asus M2N-MX se plus board.... compatible with GF
maybe it is an AGP slot, there is also a pci-e slot.
Jul 13, 2009 | ASUS M2N-MX SE Motherboard
M2n-mx se plus with amd64 5200 automatic shut down
it might be a bios problem. Check that your harddrive and cdrom are set correctly too. For example if your harddrive is set to master and your cdrom is set to slave, change the cdrom to master and harddrive to slave and see if this helps.
Oct 23, 2008 | ASUS Motherboard, GeForce 6100, Athlon 64...
ASUS M2N-MX Motherboard Logo
219 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
