Question about HP DeskJet 1220c InkJet Printer
When sending print job - does not print and shuts down program
I created a print file in Powerpoint 2003. Sent it to the printer and then Powerpoint automatically shuts down - the file is not saved and the printer's middle light continues to flash. I checked the printer and no file is showing as been in the queue
To test if it was a Powerpoint problem I tried to print the same pictures out of Word 2003 and it did the same thing.
I removed the printer and all supporting files. I reconnected the printer and let the computer find it as new hardware and automatically load the driver. It solved the problem.
Posted on Jan 18, 2009
How do I fix corrupt power point file?
If Insert ' Slides from File doesn't work and Open Office's Impress doesn't work, then the file is kaput. Start looking for your backup or in your email "sent" folder (if you emailed it ?at any point, that is). This program works well. I hope it will help you. http://www.powerpoint.repair/
Nov 10, 2015 | Microsoft PowerPoint 2003 for PC
How do I get my prtscn to print straight
Instructions
  1. Use PrintKey2000 to Direct Print
    • 1Download and save PrintKey2000 or PrintKeyPro from the "Resources" section. Save the file in a folder named "Printkey" on your "C:" drive. Double click the .exe file and follow the onscreen instructions for a problem-free installation.
    • 2 Access the Print Key program by double-clicking the hand icon in the bottom right hand corner of the task bar.
    • 3 Double click the "Options" tab in the upper right hand corner. Click on "Define Hot-keys." Set a hotkey for printing the full desktop and for printing the active screen you are in.
    • 4 Navigate back to the "Options" tab and select "Direct Print (No Dialog)" so that it has a check mark next to it.
    • 5 Select the "Printer Options" function on the main program screen. Select the printer you want the print jobs sent to.
    • 6 Select a screen to use as a test. Press your hotkey for printing the full desktop and then the hotkey to print the active page. You want to make sure both functions work properly.
    Use the Print Screen Function Without a Plug-in Program
    • 7 Press the "Print Screen" key on the keyboard to print the full desktop. Press the "Alt" key plus the "Print Screen" key to print the active window.
    • 8 Click "Start" in the lower left of the taskbar. Navigate to "Applications" and choose the Microsoft Paint program.
    • 9 Click "Edit" in the program screen and click the "Paste" option. You will now see a copy of your screen capture.
    • 10 Navigate to "File" and save the screen capture as a .jpeg file. Navigate to "File" again and click "Print" to send the job to an installed printer.
    Using the Print Key Function with ScreenShot 2 Print
    • 11 Download and install ScreenShot 2 Print. ScreenShot 2 Print has a free trial option, and as of May 2010, costs $7 for the full version. Configure the program to print to a designated printer from the onscreen commands. The screen captures will print automatically when the required keys are pressed.
    • 12 Hold down the "Control" key (Ctrl) and the "Print Screen" key to capture a screen shot of the full desktop. The image will be sent directly to the designated printer.
    • 13 Hold down the "Shift" key and "Print Screen" key to take a screen shot of the active window, which is sent directly to the printer.
May 21, 2014 | Microsoft Computers & Internet
I have made an powerpoint presentation.I want to send it as an email.but when I click the send option.it doesnt get sent.what can be the possible problems? I go to microsoft power point.Select the file for...
Because you must use another program to send it - like Outlook.
Just do it the correct way: save the ppt file on your pc, close PowerPoint, open your mail program (Outlook or whatever) , compose a new mail , attach the ppt file to it and send the message to its destination.
Jun 29, 2010 | Microsoft Office PowerPoint 2007 Upgrade:...
Can't print from powerpoint viewer with Kodak 3250 printer.
hi, the reason why you can't print it it because your print was set only print for text.. go to the printer properties then set it back to image.. or re-install the driver of your printer might have corrupted..
regards
Mar 20, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
After a ps print job is sent and printed by the
There is probably nothing wrong with the printer, but it may not be be receiving all the dope it needs. Usually the printer needs a CR/LF signal at the end of the file to print. If it doesn't get that it will assume that it hasn't got all the file and will hang. This may be a setting in the application producing the file, or a setting on the printer itself (i.e needing either a full CR/LF signal or just one of these). Don't like the idea that it doesn't print its own test page though....
Dec 01, 2009 | Ricoh Aficio CL7000 Laser Printer
SAVIN PRINTER INITIALIZATION CODES
I need to see a sample of the data file being sent to the printer. Please create a, "Print to File" and then send the file to me.
I also need to see the formatting commands that you are sending to the printer.
Don
don.farr@verizon.net
Oct 19, 2009 | Savin 9935DP Laser Printer
The printer is printing an addition page each time a page is sent
Are you using a custom written language application or are you using an application such as Word?
It appears that you are using a PJL wrapper around the print job. Please create a print to file (off of the driver screen) and send it to me at janddgasrepair@verizon.net. I'll be able to look at the job and see what ie happening.
Right now I suspect that you are not clearing out the PJL properly.
Don
Apr 04, 2009 | Lexmark T520 Laser Printer
Unable to open .pps attachments from windows mail in windowsvista
If you have Windows XP:
Manual fix
  • Click Start, Run and type CONTROL FOLDERS
  • In the Folder Options applet that opens, select the File Types tab
  • Scroll down and locate the following entry:
PPS (Microsoft PowerPoint Slide Show)
  • Click Advanced
  • Click the New button
  • Type Open in the the Action: text box
  • In the Application used to perform action: field, type the following exactly:
For PowerPoint Viewer 2003:
"C:\Program Files\Microsoft Office\PowerPoint Viewer\pptview.exe" "%1"
For PowerPoint Viewer 2007:
"C:\Program Files\Microsoft Office\Office12\pptview.exe" "%1"
  • Uncheck the Use DDE box
  • Click OK, OK
  • Close the Folder Options dialog
-Tha Mp3 Doctor
Dec 31, 2008 | Microsoft Windows Vista Home Premium with...
How do I create association program in Folders Option to open
You probably do not have a Power Point viewer available; you can download it here:
'97-'07 PP viewer
Dec 22, 2008 | Microsoft PowerPoint 2003 Student &...
Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
Oct 10, 2007 | Canon ImageRUNNER 3570 Copier/Printer
HP DeskJet 1220c InkJet Printer Logo
104 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
