Question about Xerox WorkCentre Pro 412 All-In-One Laser Printer
Unprinted stripes on sheets
When I copy documents there are two unprinted stripes running top to bottom, about 5/8 wide, 3 inches apart. Not always in the same location. The problem is the same whether I feed through the document feeder, or place the original on the glass.
  • 2 more comments
  • djbrugger Jan 16, 2009
    Thanks for the reply. I have only used it as a copier, never as a printer.
  • diegocut Apr 07, 2009
    excuse my English, WorkCentre pro412 problem on the sheet is printed
    only on the right and very clear, as you can? what's the solution?
    Thanks, DIEGO - ITALY
  • diegocut May 11, 2010
    ok I have to replace the drum? I have to clean the drum, what can I do to mount the scanner?
  • Muggs01
    Muggs01 May 11, 2010
    does the printer print ok normally?
Hello, excuse my English, WorkCentre pro412 problem on the sheet is printed only on the right and very clear, as you can? what's the solution? Thanks, DIEGO - ITALY
Posted on Apr 07, 2009
  • 72 Answers
Could be the drum causing the issue or the scanner assembly.
Posted on Jan 16, 2009
White unprinted band on the top end of printed sheet
Look to make sure your developer is flowing evenly on the mag roller. Next I would check the scoretron\grid it is the saw tooth blade that faces the drum.
Aug 18, 2014 | Sharp AR-5320 Black and White Copier
My printer will not cut off and i can 39 t print and i get a co
Unplug the printer from the power source. Press and hold the power button for sixty seconds. then plug it back in and turn it on. that should clear your error. Then check for unprinted documents in the print queue by clicking on the arrow next to your clock and right click with your mouse on top of the picture of the printer. Open your print queue and delete any unprinted documents you see.
Oct 24, 2011 | Lexmark Z2300 InkJet Printer
I have a fax-jx200 it shows ;auto print off . so there are faxes in memery how do i get to turn off auto print.
Press [ON/OFF] to select <auto print off>
The fax starts receiving documents to the memory
To cancel press [ON/OFF] again.
Oct 20, 2011 | Canon FAX-JX200
JX500 says "rec'd in memory" and "auto print
I can email you the user manual for future use. LBrown18062@hotmail.com Lawrence Brown
Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Sep 29, 2011 | Canon FAX-JX200
How do you retrieve the old faxes? The paper wasnt in the right feed and a bunch of faxes came in and it never got through. I need to retrieve it.
? Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [{] or [}] to select , then press [Start/Copy].
3 Use [{] or [}] to select .
the LCD.
Jan 31, 2011 | Canon FAX JX200 Fax / copier Plain Paper...
HP 6110 all-in-one.....Connected to PC correctly...it has ink.....it prints a report...BUT it will not make a copy when an item is placed on glass and it will not print when right clicked....What does do...
Try printing it from the ADF (Automatic document feeder) if it prints from there... If same thing happens just check if the scanner bulb lids up or not... If not then its the issue with the scanner bulb
Oct 21, 2010 | HP Photosmart C6100 All-In-One Printer
Zebra stripe wont print properly
Check the printhead pressure. there is an adjustment screw that does this. It could also be that your platen roller is worn or that your printhead has burned out pixels.
Dec 30, 2009 | Zebra Stripe S600 Thermal Label Printer
Hi my mp530 printer, has a barcode like pattern
Try removing the printer from installed printers in Windows, and reinstalling the driver.Also test a different USB cable.
If the problem persists, test the printer on a different computer, if it still does the ssame, then the printer has a faulty logic board.
Jul 29, 2009 | Canon Office Equipment & Supplies
I changed the black toner cartidge for the first time and immediately got a multicolored stripe all the way across from top to bottom on the middle of the right side of the page. I replaced the toner
Vertical streaks or bands appear on the page.
One or more print cartridges might be low or defective. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges
Marks repeatedly appear at even intervals on the unprinted side of the page.
Internal parts might have toner on them. The problem typically corrects itself after a few more pages. The paper path might need cleaning. Clean the device. The fuser might be damaged or dirty. Clean using instructions in HP Toolbox.
Contact HP Customer Care.
Read this HP document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 25, 2009 | Office Equipment & Supplies
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Xerox WorkCentre Pro 412 All-In-One Laser Printer Logo
149 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
