Question about Samsung HT-DB600 System
Ht-tx35. no sound
I have no sound coming out of the 2 rear speakers and the centre speaker. the front 2 are fine. any ideas?
nev
2 Suggested Answers
t_nucca
SOURCE: no sound
you need to scroll through the modes on the remote to get to the setting you want. There is a bunch so go slow and see what one serves you better. T
Posted on Apr 30, 2009
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Samsung DVD home theater ht-tx35 protected error.how to solve?
Make sure your speakers are connected correctly. Try disconnecting the speakers and turning on the system. If you still have an error message than your system needs to be serviced. It may be the output transistors inside your system which require an expert tech to fix.
Dec 01, 2010 | Audio Players & Recorders
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
Aug 06, 2010 | Logitech X-530 Computer Speakers
I cannot hear any talking out of my surround sound system only amplified sounds
Check the speaker connections to your centre speaker and indeed the the centre speaker itself in case it has been damaged.
95% of voices are directed to the centre channel speaker (if you don't have one you need to reconfigure your HT amplifier so that it knows and redirects voices to your front left and right speakers)
Feb 07, 2010 | Audio Players & Recorders
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
No sound
Jan 16, 2009 | Samsung HT-DB600 System
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
No sound from main speakers.....
WHEN YOU SET ZONE 2 ON DID IT ASK YOU TO OUT PUT ZONE 2 ONLY OR MAIN + ZONE 2? IFF SO TRY SWITCHING MAIN ON AND IFF THIS DID NOT WORK MAKE SHURE SPEAKERS ARE SWITCHED ON IN MAIN MENU.
I KNOW THIS IS 2 LATE 4 YOUR NEW YEARS PARTY BUT I JUST FOUND THIS SITE 2DAY.
HOPE THIS HELPED.
CABLE GUY.
Dec 25, 2007 | Onkyo TX-SR601 Receiver
Samsung HT-DB600 System Logo
80 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
