Question about Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill
Unit wont turn on
After approx 30 min of total use unit won't turn on. this is the 2nd unit that i have had problems with, 2nd unit is out of warranty.
  • ptloma Feb 15, 2009
    I HAD PREVIOUSLY CHECKED EVERY THING MENTIONED EXCEPT THE ARMATURE, BOSCH MUST HAVE SOME DESIGN/QUALITY PROBLEMS WITH THESE UNITS. THIS SECOND "BAD APPLE" SURELY MESSES UP MY LONG APPRECIATION OF BOSCH PRODUCTS, IT'S BACK TO A RELIABLE BRAND.
    THANKS FOR THE HELP
  • 211 Answers
Hi
First check the power suply cord(the conductivity),the on/off switch,the brushes,the fan and the armature.The wires too.
best regards savumihai71
Posted on Feb 12, 2009
My scion xb 2005 wont start i charged the battery for 30 min or so and still wont start but i can turn on the radio, lower the windows, and start the air conditioner(does not get cold)
Still possibly a battery fault, radio uses about .3 amp, windows 3-5 amps, STARTER needs approx 30 amps. So a bad battery will power the auxiliaries but not the starter. Try a boost start from a known good battery and take it from there.
Jan 28, 2014 | Cars & Trucks
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
How to program a 2000 cadillac seville sls keyless entry remote 25656444
you have to do a thirty min relearn procedure. with the master key , turn on the ignition observing the security tell tale lamp for approx ten min or when light goes out. turn off ignition and wait for approx 5 seconds. repeat above procudure two more times for a total of about 30 min. start vehicle .
Apr 01, 2013 | 2003 Cadillac Deville
The average distance from the sun to the earth is 93000000 miles. how long does it take the light from the sun to reach the earth if light travels at a rate about 186000 miles per second? with solution
Taking 93000000 Miles as Distance between earth and sun, you want to know how much time it takes for the light to touch Earth's atmosphere
93000000 / 186000 = 500sec
500 secs is 8 min 30sec Approx
so it takes 8 mins and approx 30 secs for light to reach from sun to earth
Jun 26, 2010 | Dk Multimedia I Love Math - 2nd (2071074)...
Mine wont turn on i think i left mine in my pocket for 30 mins and now it wont charge turn on or be regonized by my computer ive tried reseting it nothing worked :'(
Leaving an mP3 player in your pocket won't hurt it.
Direct sunlight for 30 min might kill it.
A pass through the washer certainly will damage it.
Moisture, such as with heavy exercise, with the unit in your pocket may cause it to fail. Moisture is a problem.
Apr 21, 2010 | Philips SA3025/37 Flash MP3 Player
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Apr 10, 2010 | Emerson EWF2004 20" TV
Dryer gets hot and turns off timmer still going,wont restart for approx 20 min
there is a thermal switch it cuts out the heater element when its at temp. also so has a thermal switch that cut out the unit if it gets to hot. there will be two thermal switches or a combined one. it will have 2 to 3 wire on it and is directly connected to the the drum. one of these is the problem the thermal switch is working as its cutting out the unit. to stop a fire.
Jun 18, 2017 | Whirlpool GEW9878LW Electric Dryer
WON'T START
my 2006 pt cruiser won"t start. the light do come on but it will not turn over just a clicking sound. i drove it for about an hour then went back to it 30 mins later and it didn"t start. just clicking sound.
Sep 21, 2008 | 2006 Chrysler PT Cruiser
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill Logo
222 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
