Question about Lexmark Multifunction Wireless Printer/ Copier/ Scanner/ Fax
X6570 fax When I send a fax it is received with black streaks on it.
    Genius:
  • 2,120 Answers
Open the document feeder and clean the scanner glass.
Posted on Jan 16, 2009
Faxes being sent with major streaks
Open the cover where the documents are loaded and clean the thin glass there. It may have some white out or dirt on it.
Jan 20, 2012 | HP 640 Inkjet Fax Machine
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
I have a Lexmark X6570 wireless and I want to send and receive faxes. How do you send a fax when you can't find the send button
Use the Check symbol instead. Here's the Lexmark 6500 Series User's Guide to give you a more detailed instructions on how to use the Fax feature for your X6570 printer.
Apr 19, 2011 | Lexmark X6570 InkJet Printer
Why can i not send a fax from my x6570 Lexmark printer
Are you able to receive faxes? This problem could be caused by several factors - e.g quality of signal, fax settings, etc. This article in the Lexmark website will help you determine and resolve your fax problem: Main Contributing Factors to a Fax Send Failure on an Inkjet All-In-One (AIO).
Apr 04, 2011 | Lexmark X6570 InkJet Printer
I have a lexmark x6570. I have att uverse phone/internet/tv. I have always been able to send/receive faxes. Now i can receive a fax, but cannot send one. When I do, the transmission report says...
Try dialing *82 and then the full fax # you are calling. AT&T sometimes has issues with caller ID functions, and I found that this caused me to be able to receive a fax, but not send one. Post back and advise whether this resolves your problem.
Best,
JudyP
Mar 26, 2011 | Lexmark X6570 InkJet Printer
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
The receiver states that our faxes that we send are unreadable down the right side of the paper--white or dark streak. The faxes we receive are ok
The glass scanner window (narrow strip of glass) needs cleaning. One "spot" of dirt will appear as a streak on the receiving end.
If you "copy" a document you can check the streak and see how effective your cleaning is.
Sep 28, 2009 | Brother IntelliFax-2820 Laser Fax
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Not receiving fax on my Lexmark X6570 coming from a computer
on a lexmark if someone send you a fax ,first the machine has to be in fax mode ,then when the phone start ringing you have to press the start button or #9 button
Oct 03, 2008 | Office Equipment & Supplies
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Lexmark Multifunction Wireless Printer/ Copier/ Scanner/ Fax Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
