Question about Brother EM-630 Typewriter
What type of ribbon does the brother em630 type writer take?
    Novelist:
  • Brother Expert
  • 297 Answers
Here is a link to the brother website...showing all the supplies:
http://www.brother-usa.com/accessories/Accessories.aspx?Model=EM630&ACASCID=2
Part Number: 7020
Correctable Carbon Ribbon (Black)
Posted on Jan 17, 2009
Keyboard want work
If your machine is not printing properly:
1.Examine the ribbon cartridge to make sure it has not run out of Ribbon. If your ribbon appears silver or gray, install a new cartridge.
2. Ensure the black lever in the center of the carriage is pressed to the rear, towards the paper. If not press it to the rear to lock the Daisy Wheel into place.
3. With the typewriter turned off, press and hold down the "CODE" Key, the "SHIFT" Key, and the "TAB" Key.
4.Restore power with all three Keys depressed.
5.When the machine sounds a beep tone, release all three keys.
6.The carrier will move to the left indicating that the memory has been cleared and the machine has been reset.
7.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com/service/default.aspx
May 08, 2013 | Brother EM-530 Typewriter
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
Feb 27, 2013 | Brother SX-4000 Typewriter
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
TYPE WRITER DISPLAYS BUT WONT TYPE ANYTHING
There are many "WONT TYPE ANYTHING" symptoms and reasons, like:
is the ribbon installed? Is it installed correctly? Is the carriage moving?
Some description of your concern would be of great help.
I guess you don't have the User Manual.
Here you'll find the PDF version of the manual.
http://www.brother-usa.com/manuals/default.aspx?PGID=10&R3ModelID=SX4000
Good luck.
May 11, 2011 | Brother SX-4000 Typewriter
What type of ribbon is compatable with a model 762 tr
http://www.fjaproducts.com/SearchMe/7540.asp?unConResults=8209
Regular Price: $15.95 ea.
Our Price: $9.95 ea.
Availability: This item ships within 1 - 2 business days. Next Day shipment method is Not Guaranteed.
Type: Compatible
Product ID: 7540
Description: This is a Solid Black ribbon. This Black Twin Spool Typewriter Ribbon is .5 In. x 24 Ft. The Spool Diameter is 2 inches.
This Black ribbon is designed to work with all of the following machines:
BROTHER 1500 ? BROTHER 2000 ? BROTHER 210 ? BROTHER 220 ? BROTHER 240T ? BROTHER 250TR ? BROTHER 262TR ? BROTHER 3060 ? BROTHER 3800 ? BROTHER 600 DELUXE ? BROTHER 650TR ? BROTHER 660TR ? BROTHER 662TR ? BROTHER 700 DELUXE ? BROTHER CHARGER11 ? BROTHER CHARGER11 C ? BROTHER CHARGER12 ? BROTHER CHARGER2000 ? BROTHER CHARGER2512 ? BROTHER CHARGER3000 ? BROTHER CHARGER3012 ? BROTHER CHARGER3500 ? BROTHER CHARGER4512 ? BROTHER CHARGER 750 TR ? BROTHER CHARGER 762 TR ? BROTHER CHARGER 850 TR ? BROTHER ELECTRIC PORTABLE ? BROTHER STANDARD PORTABLE ? BROTHER XL1010 ? BROTHER XL1012 ? BROTHER XL3112 ? BROTHER XL3612 ? BROTHER XL4612
Jan 19, 2011 | Brother Office Equipment & Supplies
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
Cant get the typewriter to print
Be sure the the ribbon has not run out or is jammed. You can test this by rotating the colored knob on the top of the ribbon cartridge in the direction of the arrow imprinted the housing.
If not, do you hear the click of the hammer striking the printwheel? If not you may have a defective main board or hammer solenoid.
Apr 18, 2009 | Brother GX-6750 Typewriter
Brother SX-4000 Typewriter - problem w/ ribbon
Make sure ribbon you have if for the typewriter you have. take ribbon off machine and type characters, you should see the small ribbon (black) part that turns the ribbon move. If not you have a problem in the printer carrier itself...
May 22, 2008 | Brother Office Equipment & Supplies
Brother EM-630 Typewriter Logo
296 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
