Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-32XBR15 I have no sound from my Sony KV-32XBR15. I thought this was due to my kids playing with the remote but perhaps not. The picture is clear. The rear speaker SW is off. There are no external speaker wires or audio out wires. The strange thing is that when I plug an open ended wire into the audio out jacks, I get an FM station blasting through the TV speakers. Can you help?
  • 3 more comments
  • Larry Gordon Jun 19, 2007
    Unfortunately, this has not helped. Picture is fine, TV set amp is working. Sound set-up has been checked and double checked. Mute is off. Still no sound (except when open ended wire is plugged into audio out jacks with the rear speaker SW on. Then I get what sounds like an FM station reception not correlated to the picture).
    Techman
    My apologies. What's the question?
    I have placed a DVD into Video 1 position. Both audio and video for the DVD play well through the TV in Video 1 mode. However I am still unable to get TV audio in TV mode.
  • Larry Gordon Jun 20, 2007
    Premtech
    Thank you kindly for your advise. I am not technically adept at doing this myself, but I am glad to be able to call local service companies and ask if they can.
    Thanks.
    Larry15
  • Larry Gordon Jun 22, 2007
    Joe Rex
    I went through the stereo, SAP, mono options
    Genius:
  • 1,074 Answers
My friend if you are not a tech you will have to take your set to qualified people to have your set repaired, the online tech has given you an amount of solution according to you none works.if you do not have the proper equipments to trouble shoot the defect on the set you will never get your set fix.so my brother stop wasting time and take your set to a tech and i guarantee you that your set will get fix.in most cases it is always some caps and audio output transistors or ic goes bad, when your set dont have sound.good luck and have a good day my buddy.or take a look in the video amp where the sound and the snyc is separated from that circuit.
Posted on Jun 26, 2007
    Novelist:
  • 114 Answers
JUST A SIMPLE THING TO TRY ... MAKE SURE YOUR TV IS SET TO STEREO AND NOT SAP.
Posted on Jun 22, 2007
  • 934 Answers
Larry, This is actually quite a common problem for this unit. The SRX module has gone bad and it's NLA from sony.. Techs, such as myself, have developed a bypass for this though and we usually give the customer the option - since it will have sound but will be unable to produce surround.. If you would like to try the bypass yourself remove the SRX module. At A-25 connector, install (2) 10uf/50v caps - At pins 4(pos) & 14(neg), Pins 5(pos) & 15(neg). If you don't want to try this yourself call a few shops and ask what they would charge to do the repair for you, it's not an expensive one. Most reliable shops know the drill on this unit. Bill
Posted on Jun 20, 2007
    President:
  • 3,130 Answers
So that means the TV sets amp is working. You will need to double check the mute and the sound setup menu. Also try a DVD on another input. If the other input works, you have a problem in the audio switcher circuit, or the sound detector in the sound IF circuit. Good Luck
Posted on Jun 19, 2007
  • 2 more comments
  • Larry  Dillon
    Larry Dillon Jun 19, 2007
    You still did not answer my question!!
  • Larry  Dillon
    Have you tried another input, are they all doing the same thing? No sound on nothing, no input, not on a VCR or on a DVD player
  • Larry  Dillon
    i cannot wave a magic wand and fix the set. you will have to have the input board tested, or the sound IF circuit, you wiill not be able to fix the set without parts
  • Larry  Dillon
    Larry Dillon Jun 20, 2007
    That's what I meant by the input board needing to be checked. I have, in the past, been able to repair this board by replacing the surface mounted caps, but it only works 50% of the time.
Blue picture with normal sound
Is the video plugged in? It may have fallen out - this is if you are using RCA style jacks - one for video, and two for sound
Nov 21, 2013 | Sony KV-24FV12 24" TV
The picture works but the audio sound does not.Could this be due to the set been connected to virgin tv media and the remote has something to do with the problem, is there any manual way to obtain audio on...
first check the speaker setting in the menu see if the speaker is selected ON. if the speaker is on then check the SAP function of the set. check this with the remote with the MTS button on the remote. keep hitting the button untill the word stereo appears.
Jan 19, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
Sony trintron--red lights
The 2 blinks is a diagnostic code that should indicate the problem circuit. This is unique to each model though. Can you confirm that the model in question here is KV-32FS120?
Thanks,
Dan
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron KV-32XBR15
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
Jun 08, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Sony MODEL KV-2585 TV
You have your information incorrect, Q is not the designation for diodes, Q657 would be a transistor. First give us the correct number for the diode and how do you know it is shorted?
Aug 13, 2007 | Sony KV-36FS17 36" TV
TV with no picture
your tv needs to be repaired take it to a tech the power supply needs to be looked upon or the related circuit.good luck.
May 14, 2007 | Sony KV-32S42 32" TV
Sony KV-27S42 not on but timer flashes
The blinking light means almost 100% that the high voltage circuit has failed. Probably need a new horizontal output transistor and flyback. Perhaps an associated resistor or diode. If you have the expertise go for it, otherwise take it to a professional. In any case be extremely careful and safe. Good luck.
Jun 21, 2006 | Sony KV-27S42 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
