Question about Datalogic QS6500BT Barcode Scanner - Barcode Scanner
Datalogic QS6500BT barcode scanner and 2D codes
I have a Datalogic QS6500BT barcode scanner that I use regularly. When the scanner was purchased, it was specially configured to be able to read PDF-417 style barcodes. The company I work for is now getting in a new part that appears to have a MicroPDF style code on the box. My scanner acts like it is reading the code, but never downloads any data to my PC. Is there something I need to do to the scanner to be able to read what I think is a microPDF label?? Thanks for any guidance here.
  • 1 more comment
  • anchorjoe Jan 16, 2009
    The scanning within the document seemed to work as far as what the scanner should be doing, but when I try to scan the barcode again it just doesn't seem to complete the read and download. I am getting the "ticks" as if it is reading, just no download. I can go back to the PDF-417 barcodes that it was reading before and can still get a read/download. I don't know what this thing is doing... Thanks for the guidance. More research needed..
    I checked the microPDF barcode from page 334 and the scanner was able to scan both the PDF417 and the MicroPDF.. Hmmmm, interesting..
  • anchorjoe Jan 19, 2009
    OK, I tried the "Disable Escape Sequence transmit" option... No good; then I tried the "GLI Escape Sequence Protocol"...No luck. Unfortunately, this part is brand new to the company I work for so this style barcode is also brand new. The scanner still does fine with PDF-417 style, so maybe I will try the sequence again with a different box of parts and see if I can get it to work. Not sure what else to try aside from asking the supplier to use a PDF-417 style barcode, or scan each part individually (100pcs/box)...
  • 58 Answers
Usually some symbologies are disabled at default.
i think you need the manual and scan the barcode to enable it for scanning.
the links is:
it's chapter 6-191 or page 279 in pdf.
you have to begin with scanning "Start" en end with scanning "END"
becarefull with printing this page and not the whole manual. there are 336 pages.
good luck
Posted on Jan 16, 2009
  • goovy75 Jan 16, 2009
    So when you scan PDF-417 barcodes it's working correctly.
    Then you have 2 posibilities.
    or the barcode you have doesn't seem right
    you need to program the barcode again but with more parameters.
    On page 334 you find a sample barcode of micro pdf 417.
    can you verify if its working like normal?
  • goovy75 Jan 17, 2009
    So the scanner is scanning the micro pdf 417 correctly.
    Now it depends on the barcode how it's parameters are.
    For example you have some barcodes with check digits or without.
    In your case at page 279 you can also configure the micro pdf.
    Disable escape sequence transmit
    gli escape sequence.
    you should try one of these.
    But first of all you need to be sure the barcode you have is correct.
    maybe another product with the same type of barcode.
    If that is working then the problem is the barcode and not your scanner.
How can read 2d barcode?
go to:
Feb 24, 2011 | Datalogic Magellan 1000i Hands Free...
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
Problems with very small Barcodes
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Jan 09, 2009 | Datalogic PSC QuickScan QS6500 Handheld...
Configuring (changing) barcode reader suffix
Reset tbe scanner and again program the scanner for your required configuration.
Aug 15, 2008 | Datalogic Computers & Internet
Problem with datalogic magellan 1000i barcode reader
the cable is USB?
if you have usb cable, you read the manual paper "default".
if you have cable rs232 you must install on a PC emulator "softwedge". Open icons and set a comm. Prefer you answer. bye Roberto
May 16, 2008 | Datalogic Magellan 1000i Hands Free...
Datalogic QS6500BT Barcode Scanner - Barcode Scanner Logo
617 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
Level 1 Expert
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
