Question about Brother CS6000i Computerized Sewing Machine
Brother computerized c s6000i will not pic up bobbin thread
I have bought 3 of these machines and they all have quit picking uo the bobbin thread. I will be sewing and the thread balls up under the fabric and breaks the needle. when I clean it out there is no error message but it willnot pick up the bobbin thread.
  • Anonymous Feb 18, 2009
    I'm heavily involved in a large project and the same thing happened to me today (2-17-09). The thread got tangled up on the bobbin side of the garment and now the bobbin thread will not pick up. I've removed and cleaned the bobbin case with no luck. Is this machine garbage now? ****!!!
    Diamond
  • 136 Answers
Why do you continue doing the same thing expecting different results? Go to your near by dealer and buy a better machine
Posted on Aug 26, 2009
  • 21 Answers
Have you got the bobbin in the correct way around, also have you put the needle in correct with the groove in the front of you.Are you using the correct bobbins,if yes to all these your machine has thrown it timing out in the bobbin.and needs to be looked at.
Posted on Jul 10, 2009
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
SewExpress
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
  • 7 Answers
SOURCE: My brother PE-400 sewing quit sewing
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Posted on Jan 03, 2009
  • 22 Answers
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
Mongo32
  • 111 Answers
SOURCE: its like it is getting tangled in bobbin casing
loopy on bottom means upper threading or tension is wrong
Posted on Aug 23, 2009
My janome wll not pick up bobbin thread
Did it pick up the thread before you removed the bobbin case?
May 07, 2014 | Brother CS-8150 Computerized Sewing...
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
I cannotl get my 270 D to even sew, it will not pick up the bobbin thread and do a thing. I have yet to sew the machine. donna
Picking up the bobbin thread has to be done by manually. Turn off the machine, open the bobbin door, lift the presser foot, hold the end of the upper thread and slowly turn the side wheel till the needle enters the bobbin race and on the way up it will catch the bobbin thread. Pull the upper thread till you lift the bobbin thread too. Put both threads to the back of the machine, close the bobbin door and you should be able to sew.
Apr 03, 2011 | Brother SE-270D Computerized Sewing...
The bobbin thread is not catching. I have rethreaded the entire machine multiple times, tried different bobbins, etc. However, the needle and thread are not catching the bobbin thread. The bobbin thread is...
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Aug 01, 2010 | Brother Disney PE-180D Computerized Sewing...
Upper thread will not pick up bobbin thread
Ensure you have routed the bobbin thread properly and that the bobbin case has been properly installed.
Feb 01, 2010 | Brother SE-270D Computerized Sewing...
"the needle is not picking up the bobbib thread"
Check everything for burs. Something is stopping it from the bobbin. Also make sure you use can air and blow any debris from bobbin area.
Aug 31, 2009 | Brother CS-8150 Computerized Sewing...
i had the same problem and realized i was using the wrong kind of bobbin. there are specific ones for an embroidery machine and specific ones for a reg. sewing machine. hope this helps
Jan 31, 2009 | Brother PE-150V Computerized Sewing...
Brother CS6000i Computerized Sewing Machine Logo
163 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
