Question about Dell Pocket DJ MP3 Player
Dell Pocket DJ does not charge using USB Cord
I have had my pocket DJ for some time now. The USB cord worked fine. Lately I am unable to charge the MP3 Player and as such have not been able to listen to it because I can't turn it on.
  • 1 more comment
  • Anonymous Jan 30, 2009
    I just got this product and can't figure out how to charge it, as it doesn't seem to charge using the usb cable.
  • fuckyou117 Mar 29, 2009
    Dell is a shitty *** company w/ ******** itt tech students for employees.
  • Juiceicoss Apr 10, 2009
    Once the battery is drained these units will only charge using the ac adaptor, once you have charged it with the adaptor it will accept a charge from a USB cable unless it is fully discharged, then you will have to use the ac adaptor again. Strange but true
    Problem Solver:
  • 19 Answers
If you find none of this has worked you need to try some other decvie in the same usb port. If it is plugged in and operates correctly, you have narrowed it down to the dj unit. Since the chord has tested good, we should go to the unit itself. Four tiny screws located on the outside of the case need to be removed in order to open it. Carefully remove the hard drive, then the battery.
Now with the cable hooked up to the usb port you will use a meter to check some voltages. Perhaps you have a friend who can help. The batteries should read 3.6 VDC. Measured like that its not a true indication of the state of the batteries, but tell us that the charging circuit is probably working okay.
Put it back together carefully, making sure every connection is properly seated and there is no damage. Try it again, making sure you hold down the button for 3-4 seconds. If you have done all of this, the problem is electronic and at a component level. Suggest you take it or send it to the repair shop dell has.
Ted
Posted on Feb 15, 2009
You need the AC adaptor, once it has a partial charge it will charge from USB but once it is completely dead the only way back is the AC adaptor. Strange but true
Posted on Apr 10, 2009
My dell axim pocket pc charges but will not turn on when i disconnect it from the usb cord
the same thing happen to me. Change your battery. I chaged mine with a new one and then it worked fine.
Sep 28, 2009 | Dell Axim X50v Pocket PC
Dell DJ 30gb not recognized in vista
try using a different usb cord and u can also use songbird to put songs on it
Aug 16, 2009 | Dell DJ MP3 Player
Pocket dell dj will not charge
It sounds werry mouch like a bad battery. Have you tryed to seek online for a report on the LED blinking code?
Jul 22, 2009 | Dell Pocket DJ MP3 Player
Dell Pocket DJ 5gb music problem
i need a drivers for my pocket dell dj 5GB model number HV03T
Aug 07, 2008 | Dell Pocket DJ MP3 Player
Dell pocket dj 5mb wont turn on
there is a pin hole to reset it.On the botom side beside the dell logo you will see it.Use a pin to reset.
Good Luck
Jul 07, 2008 | Dell Pocket DJ MP3 Player
Quick question re: Dell pocket DJ 5gb....
From what I have read, yes, it charges via USB.
May 19, 2008 | Dell Pocket DJ MP3 Player
Dell Dj 5 will not hold a charge
FYI, replacing the battery did not solve the problem of the battery refusing to charge. Instead, I've spent $30 at batteryship.com and since I've opened the battery I can't return it. There must be a software or hardware failure that's preventing the unit from charging the battery.
Mar 12, 2008 | Dell Pocket DJ MP3 Player
Dell Pocket DJ MP3 Player Logo
498 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
