Question about Nokia 1600 Cellular Phone
Prepaid service disabled on net 10 service
I entered the wrong code after i added min today and it disabled my prepaid service. i just added 300min earlier today
Why does it says service disabled?
Troubleshooting > Prepaid Disabled/Unit Disabled
  • What should I do if my phone displays "Prepaid Disabled", "Unit Disabled", or "Prepaid Service Disabled"?Please go to "Service and Support" and select the technical support, on our website and follow the instructions provided.
  • Why does my phone display "Prepaid Disabled" or "Unit Disabled"?
    When you unsuccessfully attempt to enter the same code more than 3 times, your phone will lock and disable the Prepaid funtion. Please go to "Service and Support" and select the technical support on our website and follow the instructions provided.
May 12, 2014 | tracfone.com
I need an unlock code for a net 10 lg800 so i can use it for a verizon prepaid
My Dear brother:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 06, 2012 | Cell Phones
How do I get my radio on when I put the wrong code n three times
Disconnect the car battery for 10 mins.
Reconnect the battery then enter the radio code.
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
Jun 04, 2012 | Mitsubishi Car Audio & Video
Need puk for LG 320G net 10 prepaid phone
If you need the PUK ( Personal Unblocking Key ) for your phone, you will have to contact your mobile phone service provider.
PUK code is related to the SIM card you are using and not the phone. So, kindly call the Customer support of your mobile service provider and they will provide you with the PUK code free of charge.
Also, entering a wrong PUK code ten times in a row disables the SIM card permanently. So, please be careful while entering the PUK code.
Hope this solves your problem. Thanks for using FixYa.
Aug 28, 2010 | LG Cell Phones
DISABLED PREPAID SERVICE
Just call net10 and look for technical support and wait for the option talk with a representative....say that you was playing with the cell phone options and don't know why the phone now display that message...they will give you a big code that you need to enter in the (menu>prepaid>code entry mode> enter the code>press ok), the phone will display "code accepted" go back to your home screen and that's it! phone come back to normal...
Mar 06, 2009 | Cell Phones
My phone is displaying prepaid services disabled
i had the same problem i was pissed but heres the solution that helped me.
1. go to www.tracfone.com
2.then go to service & support and click on technical support
3.then enter your phones serial number in the "Report Technical Difficulties" box.(to get your serial number go on your phone hit menu,then hit prepaid,then hit serial number.)then hit submit.
4.then once you hit submit scroll all the way down to "prepaid disabled unit disabled".
5.then click contiue once you get there then just follow the steps along the way.
hopefully this works for you
Jan 11, 2009 | Cell Phones
Puk disabled card blocked
if you have entered the puk code wrong around 10 times you have disabled the sim card, you can cut the sim card into peaces and throw it out from the window since you will have to contact your phone service provider for another sim card or if you have prepaid buy another set.
before throwing the sim card away I suggest you contact the service provider to see if they can help you. if the card isnt blocked yet.. or if you can still enter a puk code you might be able to fix it by calling the provider and getting the correct code if not, its useless card.
Jan 02, 2009 | Samsung SGH-C300 Cellular Phone
Tracfone service disabled
Go here.... http://www.tracfone.com/case_select_action.jsp?nextPage=case_select_action.jsp&task=tech_support and enter your serial number.. then click on "Prepaid Service Disabled" ... It'll tell you how to fix it.
May 15, 2008 | Motorola Mobility 120t
Sim blocked
So have you contacted your service provider? The sim card is blocked, either you have entered the pin code wrong 3 times - then it asked for puk code and you have entered puk code wrong 10 times so its become locked.
your only option is to call the phone service provider, or buy a new sim card / prepaid sim card.
just call your service provider
May 12, 2008 | Motorola Mobility C115 Cellular Phone
MOTOROLA 120 tracfone
I had the same problem . After entering wrong code numbers,it disables the phone after four tries. The only way to get it back is to call customer service at 800-867-7183 . press 1 for english. the next menu
press 4 and the last menu press 5 to talk live to technical support. They will not ask you what you were doing to disable it.They will have you go to code feature off my prepaid menu and you must type in the 24 digit code they give you and then press ok.Then you are back in service with no charge. Hope this answers your question.
Oct 19, 2007 | Motorola Mobility 120t
Nokia 1600 Cellular Phone Logo
507 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
