Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
The rollers on my hoover widepath won't turn
When i turn on vacuum the rollers won't turn
  • Anonymous Mar 19, 2014
    my vacuum will not turn on at all. outlet is good, cord is good.wont even make a humming sound
  • 294 Answers
On this model the brushes will not turn on unless the handle is tilted back and the switch is set to carpet. if you are already doing this, then one of the likely causes would be the gear motor assembly. If that sounds expensive it is costs around $65.00. for the part only
Posted on Jan 17, 2009
What size bag does a hoover widepath preferred use
Hello! The Tempo Widepath takes the Hoover genuine type Y bags. Follow the link to place an order for the type Y bags. Type Allergen Bag 3 pack
Hope this was helpful!
Jul 02, 2014 | Hoover Vacuums
It won't pick up
Almost certainly if your vacuum is otherwise operating correctly but not picking up it will be either a blockage or a broken belt. The belt is super easy to check, turn the machine on and put it in normal operating position and tilt the head so you can see the roller. If it is not spinning it is going to need a new belt.
The blockage is a different matter and you will need to test suction at the hose, then the front to figure out where the obstruction is to be able to remove it. If you need more help please provide the model and make of your vacuum.
Regards Alec
If you need vacuum parts in Australia click here.
May 23, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
May 02, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Hoover belt 38528 is broken where can we find the replacement part and how can I install it again? or is there a place to get service for this vacuum cleaner?
Try your local yellow pages and see if there's a vacuum shop around your area. If so, they will be able to help you with a replacement belt and assist you on putting it on.
Most vacuum shops carry parts for Hoover and will service the vacuum (change filters, clean brush rollers)
Mar 22, 2010 | Hoover Tempo Widepath Upright Vacuum -...
The brush doesn't turn when the machine is running
Hello. Here are some possibilities:
1. Your belt is broken
2. your roller brush end bearings are bound by hair or string.
3. Or both!
Unplug the vacuum, flip it upside down, manually turn the roller, is there resistance? If not, the belt is broken, and the roller is okay.
Nov 15, 2009 | Hoover Tempo Widepath Upright Vacuum -...
After using my attachments I have a hard time getting suction when using upright again - how do I get the suction on my upright? It's a Hoover blue widepath Tempo~ thank you
It may be clogged underneath the vacuum where the roller is. Take the bottom plate off and look into the intake port. There may be some blocking the port.
Nov 09, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
How do I replace the belt on my hoover wide path fold away vacuum
on this model there will also be 2 more screws at the top near the back on each side. the hood will come off. there will also be a cover over the roller, remove this with 3 screws, this will expose the area of the belt.
Feb 26, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
112 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
