Question about Fine Digital FineDrive 400 GPS Receiver
My finedrive 400 doesn't show anything on the screen
It worked fine until I removed the connector from the cigarette lighter adapter in my car without shutting down the system by pressing the "shut down" button.
Thanks for your help.
Ron
    Scholar:
  • 107 Answers
Does it boot at all? you should see the finedrive splash screen, then the main menu for a second or so, then it tries to load maps, how far does yours get?
if it boots but does not load maps or if it gives you an error then you have two options:
one solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
Now, if it does not boot at all, no splash screen, you could have other issues, if there is an image but no backlight (hard to see but try looking at an angle) and you get responses to key presses, then your backlight could have failed.
if it seems to lock up on boot try holding down the two right hand keys on power up, this should bring up windows CE, if it does you may have a chance at recovering by manually running the repair data I sell to recover the firmware.
Posted on Jan 18, 2009
The cigarette lighter on my 1995 Toyota Corolla does not work. The radio works fine. The problem started after I used an air compressor to inflate my tires. The air compressor attaches to the cigar
On the back side of the lighter there is a fusable link between the incoming power wire and the metal tab that connects power to the lighter. This is a very small wire, bent 90 degrees, between two tabs that are mounted on the same small screw. It looks like the incoming power tab and the power to the lighter would be connected, but they are insulated from each other on the screw. If the fusable link is blown, you will have power at the power connector on the back of the lighter, but no power to the center terminal inside the lighter.
Nov 04, 2012 | 1995 Toyota Corolla
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Cigarette Lighter Pulled Out
there could be a wire in side the unit its self and that might have come dislodged
try it and let me know
Feb 28, 2009 | 1999 Toyota RAV4
Powering finedrive 400
the home key (top right) should get it to power up but if not, you may have other issues. try to see if there is an image with no light on the screen when it powers up. if so, your backlight may have failed. in this case it should also respond to key or screen touch. if neither you could have a hardware issue where it does not boot...
Feb 27, 2009 | Fine Digital FineDrive 400 GPS Receiver
The part that Pulled out Should Screw into the Part that is still in the Car.
Jan 21, 2009 | 1999 Mitsubishi Eclipse
Findrive 400
nope, finedrive does not even answer the phones. looks like they are gone. because of this I have posted the update files to fix many of these issues, give it a try:
here is the link to the instructions and install data.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
Feb 09, 2008 | Fine Digital FineDrive 400 GPS Receiver
Recharge
The car charger worked fine in my car, but if it doesn't work for you, you can always charge it using the USB cable with your computer.
Dec 25, 2007 | Garmin StreetPilot c550 GPS Receiver
Fine Digital FineDrive 400 GPS Receiver Problem
The company went bankrupt. I get a "unable to read map data error". Called for over a month, sent email after email. Finally contacted a company that fixes Finedrives and they told me the company (Fine Digital) is out of business and will not warranty the unit...ten months old at the time. The company who fixes these machines said that it would be cheaper to buy a new(different company) gps system compared to having them fix the Finedrive 400.
Oct 31, 2007 | Fine Digital FineDrive 400 GPS Receiver
Fine Drive 400 GPs
that sounds like the inverter for the backlight is failing, you can probably make out a dark image when its out.
fine digital had a repair service for these, I think it was about $100...
Aug 08, 2007 | Fine Digital FineDrive 400 GPS Receiver
Open Questions:
Fine Digital FineDrive 400 GPS Receiver Logo
74 people viewed this question
Top Fine Digital GPS Experts
ChuckyMo
drivealot
Iqbal Husain
Iqbal Husain
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
