Question about Dishwashers
Bosch Ascenta SHE4AM1 Start any cycle. Active light is on. Spraying starts, but only lasts 5-10 sec., the active light goes out, clean light comes on and dishwasher sits doing nothing more.
  • Blanka Soltys Jul 04, 2013
    i GOT EXACTLY SAME PROBLEM WITH SAME DISHWASHER. THE DISWASHER GAVE ME 4 YEARS OF GOOD SERVICE. LAST BOSCH DISWASHER LASTED 10 YEARS IN BUSY HOUSEHOLD. ARE THEY MADE NOW IN CHINA??
I have the same problems..Did somebody tell you what to do to solve it?
Posted on Jul 25, 2009
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Problem with my bosch wash mch
Check timer to insure the cycle is completing sometimes the vacuum sensing line gets plugged and cycle may not complete
Robert
Mar 04, 2015 | Bosch Washing Machines
At start up the machine goes directly to CLEAN after about 2 minutes
Step 1:
Have the same problem with my dishwasher Bosch SHE4AM12UC. Bosch authorized repaiman has been out 3 times and changed main power board module 3 times, on the manufactures recommendation--he's given up fixing it and Bosch won't help either, just tells me to call somebody else on their list and get a second opinion (of course at my expense for labor). Anyway, steps are listed below that have worked for me to keep it limping along until I can get this figured out hoe to fix it.
Step 2:
When you start machine listen for drain pump to start up. Open door and you will hear sucking noise if it is running drain pump.
Step 3:
While you have door open, hold in start button and close door (this may take several times doing this) . Listen for the water to start to fill and wash pump will start (you will hear water spraying around from was arms). Machine will start and run normal cycle once this happens. If you don't hear this within a couple of seconds of procedure above, repeat the sequence until it works. Remember i said it may take 2-3 times to make it go.
Step 4:
Hope this helps. I'll keep trying to figure this out and come up with a solution. Forget trying to get anything done from Bosch or their "authorized" repair people as neither of them have a clue on how to solve the problem.
Jan 27, 2013 | Bosch Dishwashers
Hp f2105 black screen after 2 sec on?
You've asked this question in two places. This is confusing--try to ask it in one place only.
I answered it in your other request.
Nov 20, 2011 | Rosewill R700J 17" Flat Panel LCD Monitor
Problems Keeping the cycle going
On the back of the selector switch there is a timer motor or clock motor assembly. The gears wear out or the motor has lost its ability to go through the cycles. Replace it and you should be fine.
Jan 16, 2009 | Dishwashers
Flashing Active Light and not taking fabric conditioner
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve. 2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
Mar 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Dishwashers Logo
984 people viewed this question
Top Dishwashers Experts
