Question about Maytag Neptune MDE5500AY Electric Dryer
A piece of the steel srum tore out during drying
The dryer has been banging a month or so when in use. stopped drying/rotating and I pulled clothing out and along with this came a 4inch by 2inch steel drum piece, sharp and jagged. This is a 2.5 year old Neptune, not overused or abused!
    Sergeant:
    Champion:
  • 318 Answers
If you can find a friend who is also an amateur welder or a professional,,you can have that piece welding back in for cheap,,,P.S. you will have to repaint the inside of your drum though afterwards
Posted on Jan 16, 2009
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Dryer stopped heating
Problem not very specific. If the srum is rotating and no heat appears, it's probably the thermostats. Depending on model, they are usually found on or near the heater at the back. There's usually two but both need to be changed. Check them for continuity first.
Dec 11, 2009 | Frigidaire Dryers
I have a Miele dryer, model T494C. The system starts rotate right then stops and when rotates left and immediatly the main relay of the house falls. After three days the dryer works fine. Is there...
It's most likely one of the heat/humidity sensor tubes that needs to be replaced. This has happened twice to my T494C in 12 years. Miele (or your dealer) will come out and replace it for a cost. Do NOT leave wet clothes (or semi-dry clothes) in the dryer for any length of time when the dryer is not operating. Apparently this is one of the problems.
Nov 23, 2009 | Miele Dryers
Hi. Our dryer will start normally and then the
HI. This will occur when the there are issues that concern the integrity of the timer motor. This mechanism is responsible for the rotation of the timer module.It is damaged at this time, and it must be replaced asap.
A damaged timer motor will affect the nature of the drying cycle. It is the main initiator of all functions during the selected cycle.
Oct 29, 2009 | Dryers
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Hear a periodic banging during rotation of the drume
usually you can check it at the back cover, check if the dryer tub is directly mounted or connected to the motor, then check the rubber stabilizer or spring stabilizer of the motor which is connected to the base. This stabilizers are responsible of the balance of the dryer tub during high speed operation or rotation of the motor. check this stabilizers and replace it if it is defective or weak.
and one thing more, just make sure that when load your wet clothes see to it that you load it at the center of the dryer tub, so that when the motor starts to spin at speed it is in a balance position.
Jan 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
50 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
