Question about Mitsubishi XL5U ColorView Multimedia Projector
Replace lamp soon flashing during warm-up
We had the projector flash the replace lamp warning, waited a bit to replace it, then did.
Now the lamp is replaced and it still flashes the warning.  How do I get it off?
Press the left and right buttons, as well as the power button once the lamp has turned on. This will reset the lamp life counter.
Posted on Feb 10, 2010
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | ViewSonic Office Equipment & Supplies
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
My Hitachi CP-X201 has a flashing red lamp light on & won't display. I replaced the lamp but it still doesn't work. WHat do I DO?
Hello :
Did you replace the lamp correctly ? If not , then i'll tell you how to do that :
Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
I hope this will help .
rate please !
If that wasn't helpful , then contact again please !
Mar 24, 2010 | Hitachi CP-X201 Projector
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
Working but lamp warning on screen,lamp led flashing
Press < and > and Power buttons at the
same time on the projector to reset the
lamp hours counter
May 12, 2009 | Mitsubishi SL1U Multimedia Projector
PT-L785U Projector
if the lamp warning light is flashing, this indicates a defective ballast (lamp power module). if the lamp warning light is lit steadily, then the lamp would be at fault.
Oct 13, 2008 | Panasonic PT-L785U Multimedia Projector
Lamp replacement
Hi there
There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
Sep 16, 2008 | Panasonic Videoprojector PT-LM1E...
Mitsubishi XL5U ColorView Multimedia Projector Logo
336 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
