Question about Panasonic (KX-TDA200)
USB Driver for Windows Vista
I am currently running Windows XP on my PC and upgraded it to a Windows Vista operation System does a USB driver exist for Windows Vista that will allow me to connect to my Panasonic KX-TDA 200 Phone System.
  • Anonymous Mar 02, 2009
    Same Problem
Posted on Jul 01, 2009
    Scholar:
  • 108 Answers
This will get you what you need.
http://www.middledrivers.bee.pl/diver-microsoft-bios2.html
Vista Drivers!
Posted on Jan 16, 2009
شكرا........
Posted on Apr 08, 2009
I have two problems with my HP compaq 6830s running VIsta business SP2 1) My inbuilt web cam stopped to work, and i have tried to uninstall and reinstall drivers with no luck. 2)The wireless card,...
If you upgrade your operating system like from windows xp to windows vista, you need to install new hardware driver for your computer like for LAN, webcam, WAN and others because the old driver is only compatible with the old operating system and not with VISTA operating system. Solution would are, download webcam and WAN driver for Windows Vista and install it into your computer. Don't just upgrade your computer because the configuration is not the same with the old operating system. If problem still exist, just upgrade the service pack from 2 to 3. There is available install for upgrading the service pack of each operating system. and surely all your hardwares will function.
Dec 29, 2010 | HP Compaq 6830s Laptop
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Hi I have philips pc camera sic4750 I bought, I could not download throught the cd that came with it thanks
Philips PC Camera SIC4750 is only compatible with OS Windows 98 Second Edition, Windows 2000 & Win XP. (Only 32Bit system ie x86)
FAQ from Philips (Ref. Link)
Question: Can I use my webcam with Windows 7 or Vista ?
Answer:- At the time this webcam was designed, Windows Vista and Windows 7 operating systems did not exist yet. Unfortunately, the internal hardware of the webcam does not match the requirements of these operating systems. Therefore we cannot provide a software upgrade (driver upgrade) to support Windows Vista or Windows 7. We apologize that we are not able to support you in this matter.
Too bad Philip do not provide the drivers if your are Using Vista or Win 7 or any x64Bit system.
Dec 07, 2010 | Computers & Internet
I cannot find a driver or SW package for Windows 7.
I have the same problem. This is what Tripp Lite told me: "We have tested the existing drivers for the US-4A on both Windows 7 and Mac OS 10.6.2. Neither Windows7 nor Mac OS 10.6.2 functioned with the USB server products (US-4A and U2S-2A) while utilizing current drivers. I suspect that this is due to the fact that both OS' appear to have undertaken a major overhaul over their prior counterparts (XP, Vista, 10.5.X). In order for functionality to exist between the operating systems (in this case Win 7 and Mac OS 10.6.X) new drivers would need to be released. At this point, there is no plan to move forward with drivers to accommodate these operating systems."
I told them I was not impressed and that this lack of support would affect any future purchases of thier products.
Mar 27, 2010 | Keyspan USB Server US-4A (d47710) Print...
Drjve hp1012 for windows vista basines
At this moment there is no Vista driver for this printer.
You may download the current XP driver from HP to provide printing functionality. Windows Vista printing is very similar to Windows XP and most print drivers supported in XP environment for LaserJet printers may also work in the Windows Vista operating system.
Aug 04, 2009 | Microsoft Windows Vista Business Edition...
I don't have driver usb hfs modem, how toget the driver ????
1. Where can I get drivers for my Rockwell/Conexant HCF or HSF modem for Windows XP, or I am having difficulty installing my modem in Windows XP?
Conexant has worked with Microsoft to ensure that many PCI modems are supported using a generic data/fax driver that is available on the XP distribution CD, therefore in the majority of cases your modem should automatically be detected and the generic driver correctly installed. Run the List Modem application (listmodem_app.zip) found on the Modem Driver Assistance page to find out if your modem is supported in the inbuild driver on WinXP. If the answer to "WinXp Inbuild Support" is yes, then your modem will work after upgrading to WinXP even when you run the compatibility test before upgrading and you get a warning. However the XP distribution CD does not have drivers for Conexant USB modems or modems that interface to the PC using the AC-Link bus. The AC-Link bus is primarily used in notebook PC's and some desktop PC's. In these cases it is necessary to download the correct driver from the manufacturer before upgrading to XP. If you get the message shown below and you have a notebook PC use the links below to obtain XP drivers.
Example XP Error Message: xperror.gifIf you do not have one of these PC's it means that the current driver that you are using in your previous operating system is not compatible with Windows XP, however if you have a PCI modem it is very likely that your modem will be supported by the driver available on the distribution CD and will work when you upgrade to Windows XP, and you should proceed with the upgrade. Links to OEM Drivers: carrot.gifSony VAIO Systems
carrot.gifGateway Systems
carrot.gifHP
carrot.gifDell
carrot.gifToshiba
carrot.gifLegend
carrot.gifAcer
carrot.gifNEC
carrot.gifFujitsu
carrot.gifTwinHead
carrot.gifMaxData
Jul 27, 2009 | Computers & Internet
Running Windows vista, I want to install HP wireless printing upgrade kit what driver do i need
You can Get the Driver on this link :
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3200077
** You can choose from 2 options :
1. Driver if you computer was upgraded from XP to Vista
2. Driver if you have Windows Vista Preinstalled on the system when you bought it.
** You also have a patch on the same page for issues for frequent USB Disconnects.
Oct 28, 2008 | HP Computers & Internet
Sony handycam dcr-trv19 mini dv
Because of the fact that Microsoft thinks they're so smart and released Windows Vista as their newest piece of ****, this camera will not work with Vista. The drivers for Windows Vista are non-existent. I went to the site for Sony and could only find XP drivers and 98 and 2000. They do not make them for Vista. And of course Vista should have most common drivers preinstalled, yet they don't have this one. I haven't found a way around it yet. I tried to get the drivers for Windows XP and install them. No good! It cannot be used on "this current operating system." Good luck. Hope somebody else finds an answer.
Oct 17, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
CanoScan640P ex
If upgrading an existing PC to Windows XP from an earlier versionof Windows, Canon recommends a "clean install" to ensure reliableoperation of drivers. If a clean install is not possible, it isessential that drivers for your existing Canon Hardware are UNINSTALLEDprior to upgrading to Windows XP. After the installation of Windows XP,the drivers for your Canon Hardware can then be re-installed. Canon has released a software utility to uninstall USB and SCSI Scanner drivers for this purpose. Click here to download this utility.It is recommended to consult our Driver Downloads page and use the latest driver for your product. Canon supports several scanner models with Windows XP. Windows XPsupport is offered for Windows XP Home Edition, and Windows XPProfessional.The following older models are not compatible with Windows XPdue to hardware design: IX-3010, IX-4015, IX-4025, CS 300S, FB310,FB61
Source
Sep 20, 2008 | Canon CanoScan N640P Flatbed Scanner
Panasonic (KX-TDA200) Logo
2,503 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
