Cannot install version 7 because version 6 wont uninstall
  • rick_elliott Jan 16, 2009
    tried that and it didnt work version 6 is still partially there and wont uninstall
    Sergeant:
    Champion:
  • 318 Answers
Remove all instances of program from registry,,you can do this manualy or by using a registry fix program
Posted on Jan 16, 2009
  • Alex M
    Alex M Jan 30, 2009
    Sometimes the program will have a parent name that it will register itself under in the system registry.
    You need to find this and delete it from the registry (believe me if the program is installed on your computer,it will be logged in the system registry) To be doubly sure you get it all,go to start and search, Files and Folders "find all files and folders" this should find all instances of the program which you can then delete from the results.
  • Alex M
    Alex M Jan 30, 2009
    When i said Parent name,,i meant a name which is different than the program name.
Missing tool bar when I uploaded to Explorer 7. I cant click on tools to get it back because I dont have a tool bar to acces
Try to uninstall IE7. Once it's removed, restart your computer then it will revert back to the older version IE6. After that you can opt to install IE7 again or much better a newer version like 8 or 9.
To uninstall IE7, kindly follow these steps:
  1. Close all programs.
  2. Click Start and then click Control Panel.
  3. Click Uninstall a Program under the Programs category
  4. In the Tasks pane, click View installed updates.
  5. In the list of installed updates, double-click Windows Internet Explorer 7. In the Uninstall an update dialog box, click Yes.
    Note If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
  6. Follow the instructions to uninstall Internet Explorer 7.
  7. When the uninstall program is finished, restart your computer.
  8. After you restart your computer, open Internet Explorer. Click Help>About Internet Explorer and check if it's on version 6. If it is then proceed with upgrading to a higher version again.
    Hope this helps.
Nov 18, 2011 | Microsoft Internet Explorer 7
Tip
For All XP user Don't Use IE 7.0 & higher version
Applicable for all window XP (all edition, all PCs and Laptops)
If you are getting trouble after the updates of internet explorer..
Then I would suggest you to Roll Back it to the original Internet Explorer (i.e Internet Explorer version 6.0)
Which come up with Installation of Win Xp with Service Pack 2.
Bad Effect due to IE 7.0 or higher version:
Screen hang up, internet freezes abruptly, prominent windows crashes anytime.
So to stop these problems, better to run with lower and safe version of IE:
To remove Internet Explorer 7 from your PC use the following methods
Method 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
Step 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
a. Click Start, and then click Run.
b In the Open box, type appwiz.cpl, and then click OK.
c. In the list of programs, click Windows Internet Explorer 7, and then click Remove.
d. Follow the wizard instructions to uninstall Internet Explorer 7. Also remove if any updates under this entry found.
If you cannot uninstall Internet Explorer 7 by using this method, try Method 2.
Method 2: Use Spuninst.exe to uninstall Internet Explorer 7
Run Spuninst.exe to uninstall Internet Explorer 7
b. In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
c. Follow the wizard instructions to uninstall Internet Explorer 7.
After you uninstall Internet Explorer 7, double-click the Internet Explorer icon to verify that Internet Explorer 6 is restored.
This will bring up you to run Internet explorer as it come up with the installation kit, which is safe and reliable.
Have Nice Surfing!!
Ellin
on Oct 14, 2008 | Microsoft Windows XP Home Edition
I installed it and paid for it but it doesn't work on my Windows 7 74-bit system.
Did you download and install the Windows 7 & Windows Vista version 3.1. If you installed version 1.2 then you need to uninstall it, restart your computer, and download and install version 3.1. http://www.easyvoiprecorder.com/index.php?option=com_content&task=view&id=15&Itemid=48 Even if you installed the correct version you may have a corrupt download. Uninstall it, restart your computer, and download and install it again. If it still will not work, your firewall may be clocking it. You must allow access through the firewall. If you still cannot get it to work contact support at sales@easyvoiprecorder.com
Jul 04, 2011 | EasyVoipRecorder
Is the hp j3640 it wont work with windows 7
This printer works with windows 7, please check if you have a 32 bit version of windows XP or 64 bit then download and install the latest appropriate drivers (before installing the latest drivers, uninstall the old driver if any)
Find the link below to download the appropriate driver
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=3540751
Once the HP support site opens up, at the top choose the right windows version you have and then download the drivers.
Note: to find the version of windows 7 you have you can click on start, then right click on computer and click properties. In the system properties you can find if you have a 32 bit version or 64 bit version.
Feb 04, 2011 | Office Equipment & Supplies
Uninstall IE8 and install IE7, the original IE, please.
Click Start
Click Control Panel
Click Add/Remove Programs
Click Show Updates
Select IE8
Click uninstall
This should "restore" your previous version of IE (6? 7?)
Or, if you're running Vista or 7, see: http://www.microsoft.com/ie9
and install "Internet Explorer 9 beta", i.e., a "pre-release" version of the _next_ version of IE.
Dec 21, 2010 | Computers & Internet
I cannot uninstall nero 7 and it is disturning me
I would suggest downloading the Nero clean tool from here
Install it onto your computer then run the program.
This will do a complete uninstall / removal of Nero 7.
Aug 11, 2010 | Computers & Internet
Yahoo messenger 10.0 wont install in my Winows 7 laptop what do i do?
Make sure you had uninstalled all previous versions of Messenger you have installed and then restart your computer.
Download, the latest version is Yahoo Messenger 10 @ http://messenger.yahoo.com/platform/win to install on your laptop.
Jul 28, 2010 | Computers & Internet
Microsoft office wont install on hp pavilion dv7
It is not clear which office you want to install weather 2007 or 2010 and which windows are you using but the following works in all cases.
You need to see whether you have any trial version of Ms Office installed on your computer, if yes then uninstall it first.
Assuming you are using win 7
Start > type Add Remove Programs.
Program and Features will open up and search for any preinstalled office. Uninstall it and restart your computer. Now try Installing new office.
Jun 22, 2010 | HP Pavilion DV7-1020US Laptop
Installing and unistalling
hello nena3
the nero 7 removel tool
Nero – Cleantools this will remove nero 7 from nero .
riz.
Apr 28, 2008 | Computers & Internet
Uninstalling Nero 7 From My PC, Running Vista
go to this link and download the nero 7 clean tool - http://www.nero.com/nero7/enu/Clean_Tools.html - then try reinstalling nero 7 essentials version - make sure you use the nero 7 essentials serial number. hope this solves your problem.
Sep 21, 2007 | Ahead Software Nero 6.0 (60045) for PC
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
