Question about Maytag PYE4558A Electric Dryer
Dryer Run too long
The dryer gets warm to the touch, but it takes over an hr or more to dry a load of cloths? Is this the Heating element?
    Problem Solver:
  • 16 Answers
Check the complete ventillation duct( in and out of the machine.) Sounds like its not moving any air. No flow
Posted on Jan 17, 2009
Only gets warm and takes hours to dry
Could be a defective heating element.
Mar 02, 2015 | Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Model/stock #...66904/669. Having to run 3-4 cycles to completly dry clothes
Sounds like your problem could be the thermostats or the heating element, they will normally cause the dryer to take a long time to dry the clothes
Sep 26, 2009 | Kenmore Dryers
My dryer isn't drying , it runs and runs and it's getting warm but not hot enough to dry a load of clothes. what's my broblem. my dryer vent is open and it still seems to me the it's not running like it...
It is possible the heating element is out of your dryer Check with Whirlpool or another service dealer to see if they have your model. sometimes it is cheaper to buy a new dryer if you have a off brand or lower cost dryer
Check the vents and filters first of all. If they are blocked at any point the air flow will be restricted and prevent drying.
The next thing would be to see if the heating element is working, whether it is gas or electric.
The heating elements could be bad and need replacing. In addition, if the dryer is not properly vented, clothes will take much longer to dry.
You should first REPLACE your exhaust hose if it has been on your dryer for more than a year. Not clean it out but REPLACE it. This not only prevents fires but also keeps your dryer at optimal performance.
Also, every 3-4 years, unplug the dryer and remove the back of it (it's just a metal panel, don't be afraid) and clean all the lint out of there. If that doesn't work, your moisture sensor may be slowly dying. If that is the case, you just have to run some loads twice. Using a pair of dryer balls helps dry the clothes faster so I recommend those too. Eventually, you may wish to consider replacing the dryer.
Aug 31, 2009 | Whirlpool Dryers
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer Run too long
Jan 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Maytag dryer doesn't dry properly
heating element is fine. it either works or it doesnt, cant work halfway, your problem sounds like you hav a clogged vent a kinked exhaust leaving the home. try looking at the exit point form the home can you see any lint around the housing, VENT VENT VENT
Mar 11, 2008 | Dryers
Maytag PYE4558A Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
