Question about Kenmore 62622 Microwave Oven
Down lights/night light not working
I have a Kenmore 62642200 that was purchased new in 2003. I've replaced the lights that shine over the stove in the past without a problem. However, recently even after replacing the bulbs they still won't turn on. A friend suggested it could be the fuse. I called & ordered one from Sears & have received it, but I cannot find any information on how to replace the fuse & where it is located. Can someone help, please?
  • William Miller
    William Miller May 11, 2010
    What is your full model number from the tag on the oven?
    A full Sears/Kenmore
    model number has 3 digits, a dot, then 8 more digits, such as
  • 54 Answers
I'll do my best w/out model#... remove 2 screws top of the air vent grill to remove grill.. remove 1 screw at top of touch pad.. you will see maybe 2 or 3 diff fuse area...thats how you get to the fuse for your question.. but I think the relay in your control for the light is bad. unforturnately you have to replace the whole board (in most over the range micro) good luck.. mike
Posted on Jan 22, 2009
How to turn the oven light off on my Kenmore Elite Electric stove model790.
You should have either a shorted out door switch or a shorted out light switch on the control panel.
Removing either one and unplugging it should show you which one is the problem.
God bless your efforts.
Nov 30, 2016 | Kenmore Microwave Ovens
Whirlpool microwave press light it diplays half or full or off???
That is referring to the under the microwave light that shines down on your stove. You have full brightness, half the brightness, or the light will be off.
Mar 06, 2015 | Whirlpool Microwave Ovens
I have a Kenmore microwave mounted above my stove. The light that lights my stove is blown and I can't find the right replacement bulb. It has two little prongs that should fit into the unders
Are these little spot lights? About the size of 1/2 dollar round and maybe 1.5 -2 inches long? 2 prongs about 1/2 inch apart? Take one of those lights and show it to a local hardware dealer like "Lowes". There are may types and some are 12V some are 110V. Thats why I suggest showing to the local hardware guy.
Jan 12, 2015 | Microwave Ovens
I have a GE micro ange hood Model# HVM1540DM1BB, bulbs blew,change them out, now the lights will not shut off. I have powered it down over night, pluged it back in next morning same thing. Any ideas
There is a possibility that the light relay is stuck on. Sometimes a sharp tap on the relay will fix it. If not the control board will need replacing.
Sep 26, 2014 | GE Microwave Ovens
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 08, 2010 | Kenmore 80599 Microwave Oven
Light does not work even after changing the bulb this is the light that shines over the stove top (Kenmore Micro model # 721.80412500
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more information or to arrange repairs.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 10, 2009 | Whirlpool MH7135XE Microwave Oven
Covers over cooking/night lights are melting
I have a microwave above my stove also but it has not done what yours is doing. I would try a lower watt bulb since it would not give off as much heat. You may need to replace the lens or else just take it out and get rid of the problem altogether. You would have a brighter light anywas even if you kept the same bulb. Most of those bulbs are florescent and do not put out much heat anyway and seldom cause heat problems, esp. giving off enough heat to melt something.
Apr 17, 2009 | Microwave Ovens
It's not the fuse. If the fuse is blown, the oven will be totally dead with no display, etc.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me
directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Jan 22, 2009 | Microwave Ovens
Kenmore 62622 Microwave Oven Logo
169 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
