Question about Kenmore 46462 Front Load Washer
Water wont go into washer
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance if neither HOT nor COLD work in any setting... otherwise it's the main controller at fault.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My washing machine wont start,its opening and turning on, all the lights are on but it wont run. Can you help me please
How to Fix Washer That Won't Start ' Washing Machine Repair
A broken washer means disaster in most homes which is why we've created this repair guide to help you fix a washer that won't start. While a washing machine ...
What to do when your washer won't fill, start or run - YouTube
? 2:00
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't fill, start or run ... Front Load Washer Won't Drain or Spin Video: Washing Machine Tips from Sears ...
Troubleshooting a Washing Machine That Won't Start ...
If your washing machine won't start, begin by looking at the power source. ... mywashing has filled with water,now it wont agitate,it's like it is dead,could this be ...
Jan 14, 2016 | Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Why wont the washer start filling ?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Sep 25, 2010 | Kenmore 23822 Top Load Washer
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pull cord wont pull
ok i assume it is a gas powered pressure washer, if the pull rope wont pull out at all you either have a locked up motor or pump if it is out and wont go back in or recoil then the spring under the engine cover has either broke or come unwound.also if it wont pull out do youhave water applied to pump? if so turn off water and disconnect water hose to relieve pressure and try to pull it then then if it starts then apply water.
Mar 18, 2010 | Garden
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore 46462 Front Load Washer Logo
14 people viewed this question
Sal De
 Brian Main
Brian Main
