Question about Gateway GT5058 Desktop PC
Mouse is not recognised
There was an automatic Windows update posted this morning, oddly my mouse has stopped working. Control panel - System hardware - mouse
is basically empty, troubleshoot and properties options do nothing.
System Restore doesn't appear to work although the task manager says
that it is running. I've also tried System Restore from safe mode and also tried roll back to previous configuration. Tried installing a new wireless mouse and keyboard and the setup options for this new combination
only allows me to toggle the add keypad only. It's like anything to do with the mouse has been removed.
    Genius:
  • Gateway Master
  • 1,102 Answers
Control panel and mouse or pointing devices
if you can't fix your settings in there then uninstall your mouse and reinstall
if that does'nt help you'll have to go add new hardware and maually install mouse
Posted on Jan 16, 2009
I need a manual
James: I could not find one for you either. However, I do know that on my own computer, I can't switch a mouse without restarting my computer or it does not recognize it.
May 25, 2015 | Pixxo MA-9EG5 Black 2.4 GHz Wireless...
Why my microsfot wireless mouse 3500 stop working ?
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp. In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Hope this helps.
Jan 22, 2013 | Microsoft Wireless Mobile Mouse 3500 Sea...
There is a problem to upload image in facebook
this might be a mouse problem
make sure the batteries are inserted correctly and have charge if applicable
usually located on the underside of the mouse there might be small plastic sticker with a phillips head screw under it rub your fingernail over the top to see if it has a screw
or make sure the usb device is properly inserted for wireless or ps2 is inserted correctly
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
Sep 14, 2012 | Fujitsu Computers & Internet
Stop mouse blinking when start open windows and over screen color resolution and size
make sure the mouse Ps 2 or the usb plug has a good seating if applicable or if its batteries that are good
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 20, 2012 | Computers & Internet
I have windows 7. Can my mouse work with it?
Hello eg251, you have to "Update the Drivers" or you will have other problems with "Hardware" too.
Do a [Microsoft Update] from the "Start Menu," paul7of9_86.jpg scroll in the "All Programs."
Do a "Windows Update" Type: windows update, in the Start Search {box}.
Go to the "Control Panel" from the Start Menu," open the Control Panel,
scroll to find "Hardware and Sound," and click on the "Mouse" applet.
Open the Mouse Properties, click on the [Driver Button] and "Update Drivers for the Mouse "
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 14, 2011 | Computers & Internet
When i connect 500GB External USB hard disk on winXP machine .I get the display on my PC that new hardware found & asking for Drivers
Let the system to search for drivers automatically. Before proceeding that place any driver cd into the CD drive if came along with your ext. harddisk so that the drivers from CD will be automatically taken by the driver installer.
Thanks
Apr 12, 2010 | Seagate FreeAgent Pro 500GB External USB...
When i put the usb in the computer it doesnt connect
I would suggest that first you make sure that your computer is updated with Service Pack 2 or 3, DirectX9 or higher, and Windows Media Player 10 or higher. To do this, I went to Start -- Control Panel -- Windows Update. Then downloaded and installed all updates as required.
Secondly, I downloaded the codec for the portable device. To do this I pluged the MP3 Player into the USB port (still not recognised), went to Start -- Control Panel -- Printers and Other Hardware -- Add Hardware and this prompted the Hardware wizard. Clicked "Next" and selected YP-U3 from the list. Then selected "Install Automatically" and Voila! The codec was downloaded and the portable was recognised.
Jan 08, 2009 | Samsung YP-U3 MP3 Player
Aspire 5101wlmi
If you have got a usb mouse plug it into your computer then go to control panel>system>hardware>device manager and go to pointing devices. Right click on the + sign next to keyboard and touchpad, click on uninstall. Then reboot your machine, take the usb mouse out. Windows will reload the correct drivers for the keyboard and touchpad as new hardware and your problem should be resolved.
I hope this helps
Nov 12, 2008 | Acer Aspire 5101WLMi Notebook
Drivers for mouse
you can try doing it from start>control panel>system>hardware>device manager then find your mouse under "mouse and other pointers. then click on the tab for drivers and click on update driver
Jun 27, 2008 | Computers & Internet
Message saying alps pointing devive has stopped working, can still move mouse pointer but cant use the scroll function
A possible fix for the Alps problem Your Alps pointer problem is probably driver related. To fix it:
1. Open Windows Explorer
2. Right click on Computer & choose properties
3. Open Device Manager (Admin password may be required)
4. Under Mice & other pointing devices, right click Alps pointing-device & choose Update driver software
5. Choose Search automatically & it will download and install the latest signed driver from the windows repositories & hopefully that will fix that problem.
Jun 14, 2008 | Computers & Internet
Gateway GT5058 Desktop PC Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
