Question about GE JE835 Microwave Oven
Turn off beep?
Is there anyway to make this unit run in silent or mute mode?
No. Not unless you are willing to tear the thing apart and do some electronics work inside.
Posted on Jun 19, 2007
SOURCE:
How to mute the beep on a Hamilton beach microwave. Or is there even a way to completely mute it. If not then is there a way to turn down the beep volume
unplug machine. you will need to remove the cover. careful for the capacitor. usually after not running for an hour or so the capacitor will completely discharge on its own. looking at the back of the control board, you ill see a small round, usually black cylindrical part about 1/2 inch high with a hole in it. cover the hole with a couple small pieces of duct tape. this will mute the daylights out of it. to eliminate sound completely you will need to unsolder this part..
Jun 12, 2017 | Hamilton Beach Microwave Ovens
My microwave has lost its beep when it has finished its time set???
What make and model is it? Does it beep when you press other buttons, or is it always silent now? It could be the speaker if there is no sound at all. Or perhaps you accidentally set the microwave to a silent setting. Try looking in the manual or searching online for silent mode for your microwave model.
Jun 10, 2015 | Panasonic NN-P794SF Microwave Oven
Mute beeps
don't know if it's inherit or not to that model --you could check your manual and check with MFG on line or you could take a hammer to it---good luck
Dec 08, 2014 | Microwave Ovens
How do I turn the mute off
I had this mute problem and found that unpluging it for 1 to 2 min. and the problem cleared.
Oct 05, 2014 | GE SpaceMaker Microwave Ovens
Suddenly the beep volume is almost mute- how to bring the volume back up?
You will most lokely need to replace the "beeper" as its components have become worn ut with time
Oct 03, 2014 | Sanyo Microwave Ovens
Whirlpool X2-20ES
If it's possible to mute or turn down the volume, the owner's manual will cover it.
If not, you may want to take extreme measures, as shown in the video.
Apr 29, 2013 | Microwave Ovens
Beeping on Sunbeam SGB8901 Microwave
Unplug microwave, open top, "several screws" look to where the keypad is, behind that you should see the control board, mounted you should see a round black device may be a speaker or pizza buzzer, verify that is sound.
May 09, 2012 | Sunbeam Microwave Ovens
Hi there, I've just moved into a new apartment and the Samsung Timesaver microwave seemed to be working fine yesterday, but it has been beeping at odd times for no reason. I turned the power off to stop...
Hi, this is usually a bad touchpad. The way to tell for sure is to kill power to the unit, take the control panel down and unplug the ribbon connector that connects touchpanel to the clock. Put it back together and reapply power. The clock will just sit there blinking and, obviously, the buttons won't work, either. if the beeping stops, then the touch panel is bad. And If it still beeps, then you have a bad clock.
Apr 03, 2011 | Samsung MC5694 Microwave Oven
Beneath the time on the clock. The word "mute"
I have 2 possible solutions for you.
1) press and hold the 0 button for 3 seconds. This may only turn the clock display on or off, but may also mute or unmute the beeps.
2) unplug the unit for 30 seconds to a minute. Plug it back in and it should be reset.
Mar 08, 2011 | Hotpoint RVM1635 Microwave Oven
GE JE835 Microwave Oven Logo
329 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
