Question about Thermasol Steamshower Generator AF Series - for 140 Cu. Ft. - SSA-140
Thermasol Error 5
When I try to turn the unit on I get an error 5 message. How do I fix it?
    Problem Solver:
  • 11 Answers
Call tech department 800 776 0711
Posted on Apr 21, 2009
Setup/configuration issue, error message, scanner error 0x10. How do I fix this?
unplug power at the wall outlet
wait 5 minutes
press and hold the power/on button for 60+ seconds
keep holding while plugging back in, and for another 60 seconds after, then release if that doesnt work it is an internal fault which would require repairs or exchange in your case
Jul 19, 2015 | Epson Expression Home XP-420 Wireless...
60.20 error
The tray 2 lifter-motor is not functioning
Unfortunatly this usually requiers parts
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness is full seated in its connector on the dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver assembly
-If the unit is still clicking/banging with a new lifter replace the tray -If the unit is still clicking/banging with a new lifter and tray see step 5 5 Replace the dc controller PCA.
Apr 22, 2014 | HP LaserJet 4350dtn Printer
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Jan 31, 2009 | Xerox Phaser 6125 Laser Printer
Canon np 6030
Replace the exp lamp and try again after an error clear.
Jun 25, 2008 | Office Equipment & Supplies
Error Message: 0xc18a101
The Ox error you are describing is an issue being seen in quite a few hp printers. The only known fix is to try is while the printer is turned on unplug from power source. Unplug the power cord from the back of the unit as well and hold the power button down for 5 seconds to drain any remaining power the printer may be hanging on to. Wait another 30 seconds and plug the cord into the unit first and then directly into the wall - not a surge protector or power strip.
After you have plugged it back in if the error message comes back up then it is a fatal error within the printer. Call hp and see if they have any upgrade units available - usually refurbished but they come with a 1 yr warranty and are significantly cheaper than buying a new unit from the store. They will also take your unit and pay to have it returned to go to an environmental recycling facility.
Feb 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
ERROR MESSAGE
The e-5 error message is caused by overheating. I had the same error messager a few months ago.
The problem was the air vent on the left side of the unit was clogged with fuzz from the carpet and dust which had accumulated over a two year period.
To fix the problem use a vacuum hose with a brush and try to get the bristles underneath the plastic grill and vacuum the metal radiator type unit underneath the plastic.
When the air vent is cleaned the unit will resume normal operation.
I had to (finally) unplug the unit and take it outside and clean the vent with a waterhose to get all of the gunk out. I also purchased a sheet of charcoal filter (a few dollars) and velcro and put my own makeshift filter on the outside of the housing over the air vent on the left side.
Feb 04, 2008 | Windchaser PACR10 Portable Air Conditioner
Error: Invalid Dim
this happened to me as well. i looked it up and heres what i found:
http://www.prenhall.com/divisions/esm/app/graphing/ti83/faq/faq.html
basically you have a stat plot on so to turn it off, press 2nd and then the Y= button to get to "Stat Plot"
one of them is turned on so press enter and select OFF. this should fix the problem!
Sep 18, 2007 | Texas Instruments TI-83 Plus Calculator
Thermasol Steamshower Generator AF Series - for 140 Cu. Ft. - SSA-140 Logo
1,524 people viewed this question
Top Thermasol Electrical Supplies Experts
woodzowl307
Jim Goldsmith
Jim Goldsmith
Are you a Thermasol Electrical Supply Expert? Answer questions, earn points and help others
