Question about Mag Innovision LT976S 19" Flat Panel LCD Monitor
Monitor screen goes out (black) 2 seconds after turning on
The monitor sceen started displaying horizontal lines shortly after turning monitor power button off, then on.This quickly escalated to mores lines, display vibrates, then monitor screen goes black after about ten seconds, but with blue power button still displaying on. Now, you turn the power button off then on, and screen displays for two seconds before screen goes completely black.
Your site is extremely misleading and fraudulent. I was under the impression that I would at least get a hint at what might be a problem instead of you folks making me wait to get a money for something answer that you could have displayed on your main page. Places like yours have no place on the internet and I'm going to find out what I can do to report you.
Thank's for nothing
Posted on Jan 17, 2009
Recently when I boot up my computer I get the monitor to display an image for about 2 seconds and then it goes to a black screen. if I unplug the monitor from the back of the computer and plug it back in,...
The capacitors for the power source are failing. This causes a short burst of power to get to the lamps, but then they cannot hold a charge to continuously power the lamps. You will have to replace the monitor. I suggest checking your warranty status and replacing the monitor.
Jul 19, 2011 | Gateway FPD2275W LCD Monitor
There is a horizontal line in my laptop sceen............vaio vgn220
It can be hardware issue with your monitor so to confierm it .... disconnect the VGA & power cable from the back of the pc and press & hold the power button of the monitor for 10 secs ...replug the cables and turn on the monitor .....as well as turn off your pc and restart in BIOS page if you still find Horizontal line its the problem with the monitor but if you dont get any Horizontal lines problems with the display drivers .... try to uninstall , reinstall and update the drivers .....
May 02, 2010 | Sony VAIO VGN-C140G/B Notebook
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
The monitor displays the screen then goes black. For example, I turn of the monitor off and then back on. I will see the screen for 1/2 second then it will go black.
Hi sglick - you will need to do a few simple trouble shooting steps to pinpoint the problem, as this can be cause by several different things.
Follow these steps and reply back with your findings: 1. Unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor. 2. Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet. 3. If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad. 4. Disconnect all connected devices except the mouse, keyboard and monitor. This includes thumb drives and camera-type memory cards from card reader slots. With the devices disconnected, restart the computer. If the computer starts and the monitor now displays a picture, a device is preventing the computer from starting or sending a proper video signal to the monitor. Update the BIOS to resolve this issue.
If doing all of this doesn't change your issue of no video after seeing it pop on, try the monitor on a different computer/laptop, and if you have one, a different monitor on the system with the problem.
Let us know what you find following these steps and we can figure out what to do next. -Trev
Oct 03, 2009 | Dell E173FP 17" LCD Monitor
Monitor displays the PC screen but switches off within 10 second
Unfortunatley your monitor is going out. I just had that problem. My sceen would come on, but after about 10min. it would blink off and turn black. I would have to hit the off button on the monitor, then turn it back on. It would work fine for a few minutes then black out again. I got a new/used monitor where I no longer have that problem.
I did check to make sure my hybernate was not activated, it wasn't, I had it set to never turn off.
Good luck.
Sep 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Philips monitor problem
Check that the pc to monitor vga lead is not loose at both ends, check your graphics drivers are upto date, although it could well be a monitor fault and replacment required, as don't think they are worth reparing these days
Nov 02, 2006 | Philips Business 104B Monitor
Open Questions:
Mag Innovision LT976S 19" Flat Panel LCD Monitor Logo
422 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
