Question about Welding Tools
Weller EC2002-0 iron won't heat
The display flashes and the iron will not heat
  • voyageurs60 May 11, 2010
    Same soldering station - EC2002-0 - Iron (EC1503A) will heat... when I turn on the station the LED display is blank and stays blank even after want up to temp... ideas? repair? Tip reads "EMA" which should be an acceptable Weller Tip for the pencil... Thanks Dan
    Scholar:
  • 104 Answers
Clean and tighten the tip, I assume it is removable. If they are loose, they will not heat
Posted on Feb 09, 2009
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Dennis
Apr 15, 2017 | Weller Welding Tools
Hello all. I just began having a problem with my Weller WD1 Soldering Station. It powers on fine and the display works, however no matter what temperature the display says it is set to it will not hea
You might want to check the iron itself with an induction power tester to see if it is getting any power to the tip. This type of tester doesn't require any dis-assembly just close proximity to energized circuits.
Feb 09, 2015 | Weller Welding Tools
Cold iron
if under warranty - return it
Apr 19, 2014 | Weller HEW100P - Heater Assembly for W100P...
Weller WES51 does not heat up unless I turn to 700 degrees or higher
You may have a broken wire in the temp sensor in the tip of the iron or near where the iron connects to the base.
Jan 24, 2014 | Weller WES51 SOLDERING STATION
Display flashes 888
This usually happens when the element and or the temperature sensor within fails replace the element sensor assembly and this should fix it, however also check first that the Triac is OK on the main board inside.
Oct 12, 2011 | Weller Wesd51 Digital Soldering Station...
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
I have a weller EC1201A iron connected to an EC2100D base unit. It is a UK 240V model with digital temp set and display. The iron does not heat up. You can set the desired temp but the display just...
its my be the controler
http://cgi.ebay.com/New-weller-control-Board-EC1002-soldering-stations-/390286420305?pt=LH_DefaultDomain_0&hash=item5adee22951
good luck...
Feb 25, 2011 | Weller Welding Tools
WES 51 LED not flash to indicate ready
the iron has a temp probe inside the pencil, most likley the problem. also these have problems with the powersupply but usually it won't heat if its a power supply problem. best guess would be the sensor in the pencil
Feb 23, 2009 | Cooper Industries Weller Soldering Iron,...
Welding Tools Logo
954 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
